Yammies Posted January 18, 2012 Share Posted January 18, 2012 Can anyone tell me if the speedo hall effect sender on a T5 in a VN/VP commodore V6 is required or does it only run the speedo on the manual cars? I know it is used on the auto models for idle control, but not sure about the manual ones. I'm trying to work out if i can get rid of the electronic part completely, or tee it inline and run a manual cable for my speedo. Quote Link to comment Share on other sites More sharing options...
cruiser Posted January 19, 2012 Share Posted January 19, 2012 im running a auto vn motor in a different car and dont have the thing on the box at all, dosnt seem to bother it Quote Link to comment Share on other sites More sharing options...
ProZac Posted January 19, 2012 Share Posted January 19, 2012 I can tell you that in a vn v8 with t700 auto, the sensor runs the speedo. The speedo then divides the signal by 5, and sends it to the ecu. The ecu uses it to determine when to lock up the stall converter. Does the v6 ecu have a pin for a speed signal input? Quote Link to comment Share on other sites More sharing options...
