mjrstar Posted August 5, 2013 Share Posted August 5, 2013 Good progress man, I would be a little bit worried (even with the glue on it) that the frost plug blanking of the balance shaft hole could come adrift with the difference in thermal expansion. I have had great success heating aluminium castings to remove pressed in bearing outer races, get to ~ 100 degrees the the outer races just fall out. I'd hate for that plug to come out. Quote Link to comment Share on other sites More sharing options...
will i am Posted August 6, 2013 Author Share Posted August 6, 2013 thanks for your input MJRSTAr will have to talk to my engineer and see what a good long term method is id hate for it to pop out Quote Link to comment Share on other sites More sharing options...
