civic_zr Posted November 13, 2011 Share Posted November 13, 2011 Anyone had experience with certifying a car with Torsion bar suspension Do you lose the factory range of adjustability because cert plates have +/- 5%? Just wondering as my car has a good 20mm of difference between the adjustment range on the factory nut, much greater than the 5% given by the cert plate. I've had a brief look through the LVVTA documents but couldn't find anything. Cheers! Quote Link to comment Share on other sites More sharing options...
cletus Posted November 13, 2011 Share Posted November 13, 2011 yep once its certed then thats the height it is possible to adjust a factory torsion setup way wrong with the available adjustment. ie just because theres thread there doesnt mean its designed to be set at that height from factory Quote Link to comment Share on other sites More sharing options...
