KKtrips Posted October 26, 2011 Share Posted October 26, 2011 Yeah that looks like you'll be pulling it out again in a moment cos of the boot ring being completely fucked.. Try Mosen's on 07 846 6671 for 2nd hand BMW parts - they will be pretty helpful TBH. Quote Link to comment Share on other sites More sharing options...
LingLing Posted October 26, 2011 Author Share Posted October 26, 2011 option A: buy an expandable CV boot which does not require the removal of the ends?option B: the likelyhood is that there will be a circular retaining ring and if you set the axle up in a vise pointing downwards a good square-on hit (not that easy) SHOULD pop then end away from the axle. option c: try and split the ends (is there a jacking bolt hole) if not drill one. will try Option B first. I think I dropped the car once when I removed the tyres and jaked the car up once, would this cause this? I thought the suspension should coupe with the pressusre Quote Link to comment Share on other sites More sharing options...
LingLing Posted October 26, 2011 Author Share Posted October 26, 2011 Thank You~! Smashed on the edges. I checked all the balls and rings they seems to be fine. Now, How do you take the center lock ring off?? >< Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 26, 2011 Share Posted October 26, 2011 With some internal clip pliers or some fiddly work with a couple of sharp screwdrivers. Quote Link to comment Share on other sites More sharing options...
LingLing Posted October 26, 2011 Author Share Posted October 26, 2011 Ok, All done, Checked all the balls, housing etc. they seemd ok. Already put them back, All I need to do is put the drive shaft back to the car. and it should be rolling. haha. Quote Link to comment Share on other sites More sharing options...
