FLAWLES Posted August 27, 2011 Share Posted August 27, 2011 have just replaced a rb20e automatic transmisson in a rb20e c32 laurel as in teh old box it had lost top gear and reverse since the vl commodore's run rb20/30e the auto's are the same, i picked one up from a holden wreaker, i can only take his worf on the trans working 100% the issue i am having at the mo is when you select either 1st/2nd/3rd or reverse there is no drive ( in the new box ) the only way to get drive is to give the car a big rev and either while revving or on decelerate the wheels start to drive i can how ever put the gear lever in Park and the wheels will not spin all plugs/linkages have been hooked up and are working and to the best of my knowledge the torque converter is sitting on the splines the only other issue is there is a pin hole in one of the oil cooler lines that is leaking but i honestly cant see how that would effect drive can any holden fans/mechs give an insight to what may be going on Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted August 27, 2011 Share Posted August 27, 2011 What's your fluid/level like? Quote Link to comment Share on other sites More sharing options...
FLAWLES Posted August 27, 2011 Author Share Posted August 27, 2011 where it should be on the cold mark, and sits on the hot mark once up to temp Quote Link to comment Share on other sites More sharing options...
