GT_Escortina Posted May 5, 2011 Share Posted May 5, 2011 Ive just won this manifold on trademe it looks two fit twin dgas/dcnf type carbs .Ive googled the part number and found 1 website with not much info does anyone no what (GTW) stands for?? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 5, 2011 Share Posted May 5, 2011 Used to have something similar to this for my pinto but never got around to fitting it, got put of by the difficulty of tunning and think i was told the cards wouldn't work well orientated the way mine were. Keen to see how progress goes will be mean. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted May 9, 2011 Share Posted May 9, 2011 Isn't this a group 1 manifold for 44 IDFs?? Had a set back in the day. Made a huge performance change on my RS2000, but the carbs went out of balance by the end of the street. EDIT. see http://www.capriracing.co.uk/forum/viewtopic.php?t=248 Mind you, this is an aftermarket IDF manifold, as mine took account of the angle of the engine, whereas these mount the carbs at the same angle as the engine. Quote Link to comment Share on other sites More sharing options...
GT_Escortina Posted May 10, 2011 Author Share Posted May 10, 2011 Just got an email about this manifold used in the first official Ford RS2000 MKI and were fited with 40/42mm cci Solex carbs Homogolated Group 2 under factory number FC 0533 FIA 5566 amendment 1/1v 1.4.1974 they look very much the same as 40mm dncf webers Quote Link to comment Share on other sites More sharing options...
