Tiger Tamer Posted August 11, 2023 Posted August 11, 2023 9 hours ago, Valiant said: Have you considered a Borg Warner 78? I will have a look for info on them. Quote
J-W-G Posted August 13, 2023 Posted August 13, 2023 On 12/08/2023 at 08:09, Tiger Tamer said: I will have a look for info on them. Used in Falcons and commodores. Plenty strong and large after market ex Aussie, loads of ratios and lsd options Quote
Tiger Tamer Posted August 14, 2023 Posted August 14, 2023 In the end I decided to use a Hillman Avenger diff. It's about 20mm wider than the Minx which is good. It has the same stud pattern so I can use the wheels I have, which are new. There could be other parts that may be swapped over if I need. Also, Quaife make go fast strong parts for them if it can't handle the power in standard form. 3 Quote
