Kingpin Posted May 10, 2010 Share Posted May 10, 2010 anyone on here know about xf era for auto boxes? or recommend any good garages? heres what my problem is: the auto is slipping if i put the boot in too hard...someone told me its belts slipping and probably knackered....so i have been looking for a replacement auto. i then called an auto place up and the said it may just need adjusting..... any opinions? chur Brett Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 10, 2010 Share Posted May 10, 2010 What year is it? You say xf, but I think you mentioned it's a '95, which would make it an nf (ie same as ef falcon)? I think the same happened in my old ef, to start with it was when I put my foot down and revs would slowly rise then it was as it a clutch dropped and power then went to the wheels. After a while it started to do it even at part throttle. IIRC there is no way to tighten the belts, which iirc was the problem, as there is no adjustment. I think the only way is to replace, which means rebuild, so you will probably find a 2nd hand box cheaper. FWIW check out fordmods.com - plenty of tech info in there if you can wade through the rubbish. Quote Link to comment Share on other sites More sharing options...
R100 Posted May 10, 2010 Share Posted May 10, 2010 Hope im not stating the obviuos, but is the fluid level to where it should be ? No doubt you have already checked but i had the same problem once and thought my box was stuffed. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 10, 2010 Share Posted May 10, 2010 Ah yes ^ this, didn't work for me but mine was well fucked, car had a tough life before I got it. Quote Link to comment Share on other sites More sharing options...
Kingpin Posted May 10, 2010 Author Share Posted May 10, 2010 sorry should have said...its an 85 fairlane. fluid level all good. i can and do drive it every day and its sweet even up the gorge. it just slips if i try and boot it from the lights or something. Quote Link to comment Share on other sites More sharing options...
