Sorensin Posted December 1, 2009 Share Posted December 1, 2009 Hey need help with a megajolt system in aucks, Would like to get sprted asap... maybe a cashy for someone? Or maybe someone could help install it? just got new engine running on old dizzy would like sorted yesterday. Cheers Matt Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 1, 2009 Share Posted December 1, 2009 if you have any Q's bro ask away you got all the parts? Quote Link to comment Share on other sites More sharing options...
Sorensin Posted December 2, 2009 Author Share Posted December 2, 2009 No I only have the mega jolt unit itself atm, i asked slayer00 if he could make me up a wheel and how much that would be. Ok what better to go through my crank or cam? Or am I forced to use either? What coil should I be buying for a 1600 crossflow? whats the best way to mount the wheel? Cheers Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 2, 2009 Share Posted December 2, 2009 collect the bits first you can start fitting stuff and not have to disable you car, once its all installed just swap over to the mega system Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 2, 2009 Share Posted December 2, 2009 as for the wheel i have a picture of one you can print out to any size and take to a guy with a lathe and mill Quote Link to comment Share on other sites More sharing options...
Sorensin Posted December 3, 2009 Author Share Posted December 3, 2009 That'd be awesome thanks, I've been told to just steal a whole system from like a mondeo or 90's capri or similar but what exactly do I need to get? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 3, 2009 Share Posted December 3, 2009 the EDIS4 module the crank sensor and a suitable coilpack (the ford ones need special leads so dont bother) a pair of twin post mitsi ones from an 80 galant etc are a good replacement, so are 3 wire suabru coil packs you have a MAP version dont you? so you wont need throttle sensor and the trigger wheel, i have heard of people using 36tooth motorcycle sprockets and filing the tips off the teeth then removing one Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 3, 2009 Share Posted December 3, 2009 just print to size then attack some steel with a grinder Quote Link to comment Share on other sites More sharing options...
sheepers Posted December 3, 2009 Share Posted December 3, 2009 just print to size then attack some steel with a grinder yea do that, thats how they were made by ford in the factory Quote Link to comment Share on other sites More sharing options...
Sorensin Posted December 8, 2009 Author Share Posted December 8, 2009 just print to size then attack some steel with a grinder How thick does the whel need to be? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 8, 2009 Share Posted December 8, 2009 5 to 8mm is good can even use panel steel and fold tabs over to make the teeth Quote Link to comment Share on other sites More sharing options...
