rwdlancer Posted October 3, 2009 Share Posted October 3, 2009 bought this as an l200 gbox but judging by the gearstick position it doesnt look like an l200 d50 box.however it does fit my l200 clutch so wtf.any help would be great this is a nice and shiny d50 l200 box And This is my box Quote Link to comment Share on other sites More sharing options...
ProZac Posted October 4, 2009 Share Posted October 4, 2009 Jusding from the shifter position, i'd say Sigma/Early Galant. Measure the distance between the top two bellhousing bolts, and also the bottom two, will tell you if its 'wide' or 'narrow' block... Will probably be narrow, but if it came out of something with a 4g5* motor, it could be either. Quote Link to comment Share on other sites More sharing options...
rwdlancer Posted October 5, 2009 Author Share Posted October 5, 2009 hmm man that sucks. theres three holes at the top of the gearbox im guessing for either wideblock or narrowblock? 110mm and 130mm. will this gearbox work in an ex lancer or shud i just not even bother trying? Quote Link to comment Share on other sites More sharing options...
ProZac Posted October 5, 2009 Share Posted October 5, 2009 Will work, but you'll need to trim the shifter hole in the gearbox tunnel a little, a couple of inches in the rear ought to do it. Might need to play with the trim inside aswell. Good thing about using this gearbox is that your prop shaft should fit it, the L200 boxes i've seen have the bigger output spline. Quote Link to comment Share on other sites More sharing options...
rwdlancer Posted October 5, 2009 Author Share Posted October 5, 2009 sweet i will give it a go. my gearbox sits forward about an inch for some reason.so maybe this gearbox will fit quite nicely.what kind of driveshaft do you use if you put a l200 gearbox in a lancer then? Quote Link to comment Share on other sites More sharing options...
ProZac Posted October 5, 2009 Share Posted October 5, 2009 Starion or similar i assume.... Check Triggers thread, some good info in there about it. Quote Link to comment Share on other sites More sharing options...
Ke36 Posted October 5, 2009 Share Posted October 5, 2009 l200 yoke on a custom driveshaft Quote Link to comment Share on other sites More sharing options...
rwdlancer Posted October 8, 2009 Author Share Posted October 8, 2009 thanks for the help im gonna give it a go this weekend see if i can get it to fit. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 8, 2009 Share Posted October 8, 2009 l200 yoke you got a spare? Quote Link to comment Share on other sites More sharing options...
