Help! please identify this mitsi gbox
rwdlancer
Jusding from the shifter position, i'd say Sigma/Early Galant. Measure the distance between the top two bellhousing bolts, and also the bottom two, will tell you if its 'wide' or 'narrow' block... Will probably be narrow, but if it came out of something with a 4g5* motor, it could be either.
Will work, but you'll need to trim the shifter hole in the gearbox tunnel a little, a couple of inches in the rear ought to do it. Might need to play with the trim inside aswell. Good thing about using this gearbox is that your prop shaft should fit it, the L200 boxes i've seen have the bigger output spline.
