d.p.n.s Posted April 6, 2009 Share Posted April 6, 2009 ok so i picked this minta up in August 2007 it was in or should i say half in a creek on a fram in Otago and it cost me a doz bottles of beer. i did start a build up topic on it when i got it home but that was so long ago and it was to have full vl commonwhore running gear then it was going to be v8 then it was to be bubble arched with a 13bturbo but plans change as you all know. its now going to be a mk1 rs2000 rep with a pinto turbo so heres the lod girl as i got her and here is what im aiming for ok so here are the pics i have of her as she is now and has been since 2007 so for the amount of pics but i would like to use this to document the build as well left rear right rear right front left front there you have it i know its a lot of work but thats cool and atleast i know what sort of condition shes in to start with. cheers dan Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 6, 2009 Author Share Posted April 6, 2009 engine wise it will be a 2.0 pinto turbo i have 205 motors ones fuked and is now just use for trying shit out the other has just been crack tested and is mint with standered bore. the crank and bearings still look like new i will be useing the 205 rods i have a set of forged low com pistons thanks davidian (off here) took me a while to get an email back from sealed power to confirm they are . as for the head im going to have a go at porting my own head (i have 3 so i can fuk 2 up lol) with help of nissmo-capri thinking of using puma race valves and a standered cam for now i have a turbo manifold thanks simon (nismo-capri) its a twin scroll maifold set up for a evo4/5 turbo and it mounts it nice and low close to the block ok inlet side im useing a set of injected throttle bodies form a zx12r they are 43mm each brock-lee is having a go at making the inlet manifold for them and ill do the plenum thanks to slayer00 for doing the flanges. i have also bought a set of fiberglass rs front guards and a new front panel. thast it for now. cheers dan Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 7, 2009 Author Share Posted April 7, 2009 just a small update on some of the stuff thats arrived front gurads rs/mexico new front i picked up from palmside evo4 turbo complete with down pipe and o2 sensor Eccentric adjustable top mounts and also a new uncut loom for a link but thats about all the money i hav saved so far gone so ill start buy slowly re-building the bottom end of the motor and stripping the whole car back to metal and go from there. cheers dan Project Discussion viewtopic.php?f=18&t=18031 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 26, 2009 Author Share Posted April 26, 2009 topic viewtopic.php?f=18&t=18031 ok so i managed to get into the garage today and started to strip the front end off once it was all off i trial fitted the front panel and it will be a nice fit. there is still a lot of rust to fix in the front befor the new panel goes back on and as you can see there is a lot of room there now for intercooler/radiator/fan as for the box section x/member at the front im thinking of just replacing with steel tube thought i would try it with the rs guard on just for shits and giggles starting to look like a escort again in the past week i have also cleaned and flushed the block and gave it a paint i will be give the bores a wee hone in the morning . i also stuck a head on so i can see what needs doing to the manifold i will need to cut the flange off the manifold and cut the manifold on an angle so the flang is back on on a 45 then the turbo will sit perfectly and ill be able to use the evo dump pipe aswell so thats it for now cheers dan viewtopic.php?f=18&t=18031 Quote Link to comment Share on other sites More sharing options...
