sthrn1 Posted December 3, 2008 Share Posted December 3, 2008 Just wanting to know what is involved in fitting a 2.0L and 5 speed into my mk 2 and if anyone has parts for sale to do so.... Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted December 3, 2008 Share Posted December 3, 2008 Gaz has started an article on how to do this in the tech article section From what iv heard for how much effort it took him it seems almost no point jsut doing a pinthoe and you may aswell go with something like a twin cam. Quote Link to comment Share on other sites More sharing options...
escorted Posted December 3, 2008 Share Posted December 3, 2008 Recomend you talk to the User Gaz. or better check out his project thread Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 3, 2008 Share Posted December 3, 2008 Two threads for the same question! If you wanted to do it and keep the standard steering box arangement then its a diff story to what I have done. I think user Slipstream (sp) has done it before tho. You have to do, sump mods, make gbox crossmember and driveshaft loop, gbox hole moved, driveshaft shortened, linkages, custom speedo cable, custom extractors, exhaust system, either convert clutch pedal to cable or gbox to hydraulic.. I went to hydraulic. Basically the same stuff you would have to do to fit most other engine in there, id just go with a newer modern DOHC engine if I was you... unless of course your trying to stay period which is what I did. Gaz Quote Link to comment Share on other sites More sharing options...
