ProZac Posted August 19, 2008 Share Posted August 19, 2008 G'day. Im transferring a 1600 4g32 and 5 speed from an EX Lancer into an LA Lancer that originally had a 1200 4g36 with 4 speed. Everything has gone fine so far, easy as pie, cept that the EX runs a return line from the fuel pump back to the tank, whereas the LA does not. If i steal the pump from the original 4g36 that does not run a return line, is a likely to flood the carb on the 4g32 i've put in place? Or alternatively, can i just block off the return line from the pump that is on the 4g32 already? Worst comes to worst i suppose i can just swap the intake manifolds over, but id really prefer not to... Coz im lazy . Cheers all. Quote Link to comment Share on other sites More sharing options...
fuel Posted August 19, 2008 Share Posted August 19, 2008 Either is fine - often aftermarket pumps come with a bung to block off the return line of the pump when the car doesn't have a return. As long as the needle valve in the carb shuts off the flow of fuel coming in when the bowl is full it will be fine. Quote Link to comment Share on other sites More sharing options...
ProZac Posted August 20, 2008 Author Share Posted August 20, 2008 Scholar and a Gentleman sir . Quote Link to comment Share on other sites More sharing options...
ProZac Posted August 20, 2008 Author Share Posted August 20, 2008 Thanks Fuel, hooked it up and it fired right up, anyone want to buy an LA Lancer with 1600? hah. Quote Link to comment Share on other sites More sharing options...
