Guest zed not zee Posted August 16, 2008 Share Posted August 16, 2008 will a oil cooler still work effiently will the fittings and the bottom ie mounted upside down ?im having clearence issues with the intercooler and this would solve them easly,i dont see why it wouldnt work any thoughts cheers Quote Link to comment Share on other sites More sharing options...
Jase Posted August 16, 2008 Share Posted August 16, 2008 hot to top works best so you may need to swap the lines if you're inverting it Quote Link to comment Share on other sites More sharing options...
esky 73 Posted August 16, 2008 Share Posted August 16, 2008 should'nt make to much difference, a factory mazda batty has the inlet and outlet on the bottom Quote Link to comment Share on other sites More sharing options...
Ke36 Posted August 17, 2008 Share Posted August 17, 2008 yea evo oil coolers have both outlets on the bottom too so shouldnt matter Quote Link to comment Share on other sites More sharing options...
