Yowzer's '75 & '76 Hillman Avengers
Yowzer
This here be my new old car.
Crunched side
Mint dashboard
So the plans at the moment is to cut out the fucked bits of the sills and B pillar and weld in the spares from my parts car, chuck on a door and get it a warrant / reg.
I need some boes with cut/paste skills to help out with the panel work, coz I don't really wanna fuck it up. Drinks of choice will of course be supplied, and perhaps a BBQ.
Future plans:
cut n polish and fix up the paint
Lower it down on some better rims
Upgrade the brakes
Chuck in a 4age on a t50 box
Eventually put in the 7age.
Future future plans which may or may not ever happen:
Supe the fuck out of said 7age with some nitrous / turboe / both
Strip out interior and fit rollcage and buckets
Fully adjustable suspension
etc...
So yeah, it may one day become a full racecar, but for now I'm aiming to get a 4age in it by trackday.
[Edit] Not happening no more, this car is gonna be a resto project, gonna keep it nice and original. [/edit]
Some basic info.
I don't know the exact history of this car.
I got it off some kids for $450. They got it as a project/fix-up car which they gave up on.
The car has; Brand new radiator, new vinyl roof, new recovered stitched dashboard, looks to have a reconditioned engine, new tires, feels like new shock absorbers / suspension is mint.
I'm guessing someone was doing it up and then got t-boned, so they sold it. These guys bought it to do it up and gave up, so I got it.
On a bad note, my brother ran over a traffic island at speed, the engine jumped from its mounts and planted the belt-drive fan into the mint as radiator. Seems the mounts were already fucked, but now the fan and radiator is too.
Somehow my car lost the ability to change gear. I figured out the pin that holds the swing lever to the gearchange shaft had somehow fallen out or broken, and that fixing it would be pretty straight forward. The only problem was was that I had to go to all the effort of taking the box out just to replace the tiny pin.
So long story short, I took the box out, hit out the remains of the old pin, salvaged a new pin from a buggered box i had lying around, go to put it in and find the box is in 2nd gear, and the shaft is twisted in such a way that the pin cannot go in.
So this here is the pin. Top one is the broken one, bottom one is what it should look like. As you can see its a small bugger.
That thing on the end of the gearstick is the swing lever, which slides onto the end of the shaft in the box behind it. The pin holds it in place
The problem. The shaft is twisted as the box is in gear so the pin hole is pointing down.
So that blows.
  • 3 months later...
Sneaky edit here
Heres some of the damage from the traffic island
And I also have a new engine.
Its a 1600 venger block bored out to 1720, has some form to toyota pistons, a grumpy cam of some description, lightened conrods, lightened flywheel, mitsi l300 clutch, and all balanced and stz.
The guy who built it shaved a tad too much off the head so piston 3 collided with the valve, thus punching a hole in the piston and killing the head. Apparently shaving the head down isn't a good idea anyway as it fucks up the combustion chamber and ya lose airflow.
So the plans for this engine is to replace the killed piston, find a good head, give it a port job, skim the block down a tad, slap on some twin 45's and chuck it in with a 5 speed. Progress is gonna be rather slow due to a large lack of funds though.
I also have some hotwires
Oh yeah and the gearbox is fixed and back in etc. Here it is looking nice and clean.
While typing this, I'm actually sitting in the passenger seat of this car in my lounge.
Till next time
Change of plans here.
The above car is now gonna be a resto project, and will remain mostly factory.
This car below will be my new track car. I can't be bothered creating a separate thread for it so both cars will live here.
That there is a '75, has an Alpine engine, 4 speed manual box, heaps of no interior.
We couldn't find the keys so I replaced the ignition barrel with a push button / switch. It has no boot lock but I have spare door locks.
I also don't have the screws :? but I can't be bothered putting the interior back together anyway.
It goes, it should be warrantable, although it still has a lack of oil pressure problem that I'm currently trying to sort out.
Gonna build up the 1720cc engine and stick that in as soon as I can, and will hunt down a 5 speed box to go with it.
More pics later when I can be fucked uploading them
Sweet, sorted the lack of pressure and got the bastard running :D
Some more pics for your viewing pleasure
Alpine engine
Awesome surface rust (which I have no intention of fixing)
The drivers side door is rusted and fucked, but fortunately the other doors are mint. I havent had a proper look over the car but it seems mostly rust free (aside from surface)
And bottom hinge
At least I have a spare door, in a slightly different shade of green
And the yuck interior (or lack thereof)
So now all I have to do is slap the door on, bolt the dash on and get some new tires and I should hopefully get a wof.
So... Things I have done to this piece so far...
Free'd up the clutch
Installed a few gauges so I know what its doing
Rigged up a sweet pushbutton ignition
Stuck on a new door
Slapped what little interior I have back into it
Stuck in some semi-sealed headlights
Got some new cheap as tires
Possibly something else but thats all I remember for now
The car at the moment
Took it in for a WoF, it failed
Needs...
Rear brakes fixed
Rust checked out
brake light is dodgy
FR Balljoint is fucked
Ford 2L escort or capri drums bolt straight on and they are alot bigger, so I'm hunting some of them down for the rear, balljoints are 'no longer available' so I need to find a good parts car to raid
Rust is an easy fix, as is the brake light
So it'll hopefully have a wof soon :?
  • 5 months later...
Might as well post an update, considering I've actually done something :shock:
Heres the photos of what the previously mentioned cocknugget did to my doors.
*waiting forever for the bloody photos to upload because I don't have a program to resize them anymore..*
In the mean time heres some stormtroopers riding hoverdogs.
My previously mint straight panels are all fucked :x bloody assholes.
Thats their shoe.
Moving on however, I did get a parts car and used the doors from that. Unfortunately the drivers door had rusted out. Same as my green one. What the hell is with that?? The other doors are fine
I cannibalized it pretty good.
Parts I acquired..
Doors (minus the drivers)
Ignition system. The Chrysler Avengers have electronic ignition.
Ball joints. Later models have longer ball joints, which improve the handling a bit. Also, mine were poked.
Top one is the later model.
So some things. That I did. Yeah.
Ripped apart the crap wiring and wired up the new ignition. Old V New
Pieces of suspension lying around my floor
And some Nolathane. The strut bar - chassis mount bushers were the most softest, useless things in the world. These should improve the handling quite well. Still need to upgrade some other parts aswell but lack of cash slows progress.
And yeah, that's pretty much it for now. The car's back together and drivable, although it still needs a bit for a WOF. I did paint the suspension parts but put them back in without taking a photo. Just picture them shiny and black and ya get the idea.
Still need to sus the rear brakes, and I will probably chuck the exhaust from the parts car in as it is a larger diameter pipe, with a single small resonator, as opposed to a giant restrictive muffler box. Bit of an odd system for a stock 1300, but it should be an improvement over the crappy exhaust I'm currently using.
Anyway, till next time..
  • 3 months later...
Get a wagon up in ya!
It's my brothers, but I get the privilege of working on it :rolleyes:
Anyway this here is what I'm aiming for. Dunno where I'm gonna get the tiger spoiler from though.
Need to remove a bit more spring from my car I think..
