jase's 72 mazda b1600
Jase
URL=http://img688.imageshack.us/i/sdc10144a.jpg/]sdc10144a.jpg[/url]
technical stuff
radiator - jeep cherokee
motor - series 2 3.8 v6
trans - t700 early model no electronics
brakes - b2000 disc's gemini booster and master standard rear
fuel system - stainless tank baffled to prevent surge standard pump
diff - standard + detroit locker 3.9's to fit
  • 5 months later...
so i finally decided to jam these in and low and fucken behold my measurements are out by 6-10mm and the rim hits
the bottom tie rod , couple options now 30mm spacer and hell flush, run 16" steels i'm having widened whilst looking for some
more unique mags or not run drop spindle and settle for mediocre slam.
advice please sparkle you want these wheels minus treads?
arghhh should have stayed inside in nsfw
no mitre joints here
and all tacked up through the guard yet to add a collector.
These panel clamps are gold but would be even better with a ball swivel on the ends,
just as they pull the bends apart unless theres parallel surfaces to clamp to.
bought some 30mm spacers = might need pump the guard a little bit or make a very small flare,
relishing the thought of giving it a go though seem to be hitting my straps on the welding front, sdc10595.jpg
going to also look into flipping the bottom arm to give a little more ground clearance will probably cap the whole arm if i do
and make a steam tube spring seat
  • 3 months later...
  • 4 months later...
