Jase Posted September 10, 2008 Author Share Posted September 10, 2008 did a little tonight dropped the x member out sump off and started to get stuff organised for zinc Quote Link to comment Share on other sites More sharing options...
Jase Posted October 1, 2008 Author Share Posted October 1, 2008 ok heres a few of the cooling work that cookes radiators have been doing for me, the core is early hiace van brand new with modified tanks to fit between the subframe, the cooler is fc3 7 spec with the inlet mounted on the side, the cooler will be bolted to the radiator and will drag air through 5 100mm holes in the bumper, the plate will go below the bumper in the centre it all mounts behind the grill and bumper although i will fold up a stainless valance or have an alloy one made with an adjustable splitter ct that front section is yours if you want it for the gemette Quote Link to comment Share on other sites More sharing options...
Jase Posted October 23, 2008 Author Share Posted October 23, 2008 got some parts back from zinc today, pretty good finish although i missed a few spots and some paint had to be scraped off, not sure whether to paint it off as well or just leave it raw, also got my new bushes which are lovells for the control arms and nolathane for the sway bar links etc Quote Link to comment Share on other sites More sharing options...
Jase Posted October 23, 2008 Author Share Posted October 23, 2008 and test fitted the new radiator will just have to do some more dummy work before i drill any holes to mount it Quote Link to comment Share on other sites More sharing options...
Jase Posted November 9, 2008 Author Share Posted November 9, 2008 had good friend put my tires on and was going to drop it on the ground but still have clearance issues with width so will wait for the diff to get finished, also whacked the crossmember back in and dummy fitted the new sump, lil odd jobs but getting progress Quote Link to comment Share on other sites More sharing options...
Jase Posted November 24, 2008 Author Share Posted November 24, 2008 started with my braking stuff for the front, vt commodore 2 pot callipers (need to slot each hole approx 1mm for mounting ) standard gemi hubs at the mo but could use the piazza ones if i cannot match rotors, rotors are to be dba280's, 300mm dia 28mm thick 46mm from back of the hub to back of the rotor these are x 500sl mercedes lol a little machine time and they should be all done fairly soon Quote Link to comment Share on other sites More sharing options...
Jase Posted December 8, 2008 Author Share Posted December 8, 2008 lol Quote Link to comment Share on other sites More sharing options...
Jase Posted December 17, 2008 Author Share Posted December 17, 2008 first sump nearly modded, brakes getting completed soon exhaust flanges cut and starting on collectors and extractor jigs Quote Link to comment Share on other sites More sharing options...
Jase Posted March 30, 2009 Author Share Posted March 30, 2009 just a little progress of late picked up some steel bands for the wheels i want to run, will be a 5x120 stud pattern centre from some form of commy steel with a yellow zincd centre welded to the chrome plated band http://img519.imageshack.us/gal.php?g=dsc01288f.jpg Quote Link to comment Share on other sites More sharing options...
Jase Posted April 26, 2012 Author Share Posted April 26, 2012 ok out with the rover and bye bye to the buick v6, i've put the deposit down and pick up a 99 chev lm7 / 4l60e and ecu etc next week, bro in laws helping me out with the 5 stud conversion by cnc'ing me some hubs and shortening and resplining 28 spline axles to suit the borg unless i can find a supplier in nz of cutom length ones ready to cut down. pics to come WlGuuhjQlms you get the idea, engine will be getting a big shove back and a bit of firewall will have to go similarly the trans hump will be being enlarged. subframe connectors and a cage to tie the body up will also have to make the list Quote Link to comment Share on other sites More sharing options...
Jase Posted May 3, 2012 Author Share Posted May 3, 2012 bought engine lined up with x member, factory cast manifolds unfortunately not an option, will drag parts car out tomorrow for drive way mount session http://imageshack.us/photo/my-images/840/sdc12151u.jpg/ http://imageshack.us/photo/my-images/59/sdc12152q.jpg/ http://imageshack.us/photo/my-images/534/sdc12153x.jpg/ Quote Link to comment Share on other sites More sharing options...
Jase Posted September 18, 2012 Author Share Posted September 18, 2012 firewall out , tunnel out, 1 subframe connector mocked up, glide on and holley sump just buttoned up Quote Link to comment Share on other sites More sharing options...
