Gaz Posted March 29, 2006 Share Posted March 29, 2006 Anyone on here use wilwood calipers for street use? I know astro does. what they like, what pads you use calipers etc...? I am looking at buying some at the moment. I have been told that they are shit tho for street use. The seals apparently always leak and they are just utter shit. Someone who knows hook me up some info. Otherwise hook us some opinions etc. Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 29, 2006 Share Posted March 29, 2006 I use mine for everyday use and haven't had a problem with them, my model doesnt have dust seals but they havent leaked at all(they're only 4 months old though), I suppose it depends what conditions you are driving in though. Mine have wilwood pads too, Burton told me to get them as they would be very hard to get here, not sure if thats true but I got them anyway, I would rather have them than have to do another order Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 29, 2006 Author Share Posted March 29, 2006 So what did you have before the Wilwoods and did they make a differance? Aslo could you not find anywhere to buy them in NZ? Quote Link to comment Share on other sites More sharing options...
mkcortina Posted March 29, 2006 Share Posted March 29, 2006 wilwoods are easy to get in auckland. kendals and cardwells do willwood. and im pretty sure you can get pad from 0800 brakes http://www.racebrakes.co.nz/index.shtml if not talk to them they will tell you the best brakes for you. Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 29, 2006 Share Posted March 29, 2006 I had recond m16 calipers beforehand with ebc green. The wilwoods just make braking alot smoother but they dont grab on or anything, but I rarely change down gears when coming to a stop because the brakes are just so good now. In saying that though I havent done any really hard braking so when it comes to the crunch I dont know much yet. Main reason I bought them from burton was that they came with mounts to bolt straight onto the m16 mounts, i thought they would be hard to get like that in nz and I didnt even look elsewhere because I thought they were reasonbly cheap anyway - $500 for the pair excluding pads. Even burton had to order them from the factory as they didnt stock them. But you may be able to order them with m16 mounts anyway as my mounts had wilwood written on them, which means wilwood make them and not burton. I would ring around first to see whats available Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 29, 2006 Author Share Posted March 29, 2006 Yes im looking to use them instead of my AP calipers. Supose I will need the spacers etc to fit them on my 22mm thick disc (capri width). Wonder if I can just order them all set up. $500 is about max I would pay. Can you also get differant piston volume so the pedal is exactly the same. Quote Link to comment Share on other sites More sharing options...
rxsumo Posted March 29, 2006 Share Posted March 29, 2006 If you are after Wilwoods for an English Ford, I would talk to Les Hunter Automotive in Christchurch. Les supplies Wilwood and will custom make hats...rotors...mounts, and he races a OSCA Escort, and knows of the braking issues with the cars. Les setup the front brakes on my old RX7, and after previously having issues with incorrect sized Master Cylinders that I inherited with the car, we resized the master cylinders to match the leverage angles of the pedals....and bingo the brakes actually started to perform. The Wilwoods are unlikely to leak.....its more than likely the caliper that was leaking was a JFZ caliper, they were prone to it because of the profile of the o-ring seals, the Wilwoods shouldnt do it unless they need rebuilding. Remember these brake components are generally race componentry, and as a result are designed to be rebuilt regularly, and as they dont have the things like dust covers, you might experience higher wear rates than for equipment that was designed for road use. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 29, 2006 Author Share Posted March 29, 2006 Sweet might give that dude a ring. I have already sussed discs and hats just need the caliper now. I didnt think the rumors I had heard were true. If the guy wasnt such a hot head I would have told him he was all shit when he told me. How long are we expecting from the calipers. For sunday street use wouldnt expect to have to rebuild them for a few years at least right? Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted March 30, 2006 Share Posted March 30, 2006 DELETED Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 30, 2006 Author Share Posted March 30, 2006 Hmm ok will check that with the cert guy I use. What other alternatives are there then? Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 30, 2006 Author Share Posted March 30, 2006 I really should ring them. will do tommorow morn.. Reason for willwood is they do the right size piston etc for my car so itd just be bolt on. Dunno about skyline ones. I have some Austin princess ones that I would go for if I decide not to use the Wilwoods. Jut thought for the price I can sell the Ap ones its only a couple extra hundred for Willwoods. And I thought id rather have Wilwoods Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 30, 2006 Share Posted March 30, 2006 australia has thousands of square km's of desert so of course they would need dust seals, my calipers are powerlites if you want to know http://www.wilwood.com/Products/001-Cal ... /index.asp Quote Link to comment Share on other sites More sharing options...
rxsumo Posted March 30, 2006 Share Posted March 30, 2006 I really should ring them. will do tommorow morn..Reason for willwood is they do the right size piston etc for my car so itd just be bolt on. Dunno about skyline ones. I have some Austin princess ones that I would go for if I decide not to use the Wilwoods. Jut thought for the price I can sell the Ap ones its only a couple extra hundred for Willwoods. And I thought id rather have Wilwoods If you want another option....I've got a few sets of BMW ones...apparently the same as early Porsche, and I have the matched 2 pot rears..... The pads might be easier to get than the Princess ones Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 30, 2006 Author Share Posted March 30, 2006 Cheers dude. I still need to come out and grab that book of ya. Have a chat to ya when I get round to that. Have started work again so have been tired most days and havnt been getting out apart from weekends Quote Link to comment Share on other sites More sharing options...
atropine Posted April 1, 2006 Share Posted April 1, 2006 yeah i run wilwoods.. although i dont know too much about the setup exactly.. i find braking pretty good.. although im not running a booster at all so they can seem a little weak at times.. especially if theyre cold.. but yeah.. i havent been doing any heavy braking with them.. and they havent let me down at all.. with a booster id think theyd be psychotically good.. Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 2, 2006 Author Share Posted April 2, 2006 I am also not palnning to runa booster, What you got on rears atro Quote Link to comment Share on other sites More sharing options...
atropine Posted April 2, 2006 Share Posted April 2, 2006 just standard drums Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 2, 2006 Author Share Posted April 2, 2006 Yeah basically same as what im going to do. Was thinking of using evo rear discs but to hard Quote Link to comment Share on other sites More sharing options...
