Drftnmaz's Daily Ke70
drftnmaz
  • 8 months later...
  • 2 years later...
well its been almost 2 years since i updated this... woops
so much shit has changed since then, went to a downdraft blow-tho asain carb
5k (O dish) with vf10, rebuild it with molly rings, ported head, 272degree cam etc
blew ALOT of diffs and axels and about 8 g/boxes, ended up with hilux 1420mm rear end(standard 1400) and a t40 box, this motor got tired from my bad tuning so slammed a 4k in there with hks manifold and vf10 with smaller front mount and shorter piping and went to a drift day, it didnt last long and melted a hole in no 3
after that i wanted more power and friend had a written off s13 sitting on his lawn he had to get rid of so i gave him $1800 and sold about a $1000 worth of stuff off it and put rest in my wagon
i could keep writing all day but don't have the time
my old daily starlet \/
so the setup at the moment is
front end
8kg coilovers
trd ae92 inserts
58mm cut off strut body
22mm longer lower arms
rose jointed caster arms
RCA's
camber plates
ae85/ke70 brakes with metal king pads
25mm sway bar
strut brace
bar linking caster mounts
fender braces
Rear
leaf springs
no brakes
no sway bar (but have ordered one from whiteline)
4wd van front shocks
bar linking rear chassis
floor cut and new rear section of tunnel remade
motor
sr20det black top
s/s manifold with BB t28
evo7 cooler
trust oil cooler (not finished installing yet)
big sump with baffels
recyc blow off valve
k&n filter
s13 computer
wheels change from week to week
  • 3 months later...
got whiteline rear sway bar for ae86, didn't fit on hilux diff because of the way they bent it... so got a standard ae86 bar and it fits on mint, made some brackets so its 3 way adjustable, took it out for a try at a drift day and its makes alot of differance, i love it
also fitted oil cooler, remade the alloy water pipe so it doesn't go under the CAS anymore
and then went to the clubk gymkhana ast weekend, and it was raining so you can imange how that ended up, soooo much fun
heres a vid of one of the fun runs where i was taking people for rides
and heres a photo by cheater_5 from the drift day, cheers to the mint pics man!!!
http://wendycainphotography.com/beeoneo ... _7731b.jpg
viewtopic.php?f=18&t=5132&hilit=drftnmaz
