Guest Scheme Posted December 19, 2005 Share Posted December 19, 2005 Hey guys, the rims I want to put on my ke70 are only available in fwd. I have on here and it fits on the rear mint, and its in the right place - except, the center of the wheel is a bit bigger than the center thats on the hub itself, therefore I believe it could put dangerous pressure on the studs? whats the best way to get around this. I need about 20mm spacers for the front, I should be able to get them machined to fit on the center correctly. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted December 19, 2005 Share Posted December 19, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted December 19, 2005 Share Posted December 19, 2005 I thought something like that would be available, would have to be pretty thick centering rings... Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted December 19, 2005 Share Posted December 19, 2005 question; if I use 20mm spacers on the front, and none on the back will that screw the handling of the car having the front wheels slightly further apart? Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 19, 2005 Share Posted December 19, 2005 yip it will mess with the handling, just get 4 spacers Quote Link to comment Share on other sites More sharing options...
