Guest olschltoy Posted July 30, 2005 Share Posted July 30, 2005 I have twin down draughts, exactly the same as a side draught but made for verticle aplication. The only disadvatane of this type of carb over a sidey is it doesnt flow as well because of the 90'' bend. But i doubt you'd notice the difference if you bolted up the same size side draughts to my engine. Thanks Defcon. I was really just wondering about the flow as I have twin downdrafts on my 3T at the mo.Think they could be factory.Thats cool,cheers Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted July 31, 2005 Share Posted July 31, 2005 The mixture screw is just for your idle and that's not where the damage is done if your'e lean. A cheat to richen your mixture through the range is to raise the float level a little at a time. Otherwise rejet. find out which way your idle screw works as some pass air and some fuel. With an air bypass in is richer and out is leaner, vice versa for fuel. Eddie Quote Link to comment Share on other sites More sharing options...
lowlancer Posted July 31, 2005 Share Posted July 31, 2005 Well it's a 32/36. In is leaner yes? And what is this speak of raising float levels? Explain please! Quote Link to comment Share on other sites More sharing options...
