Guest escort_boy Posted May 9, 2005 Share Posted May 9, 2005 do sierra strut assemblies drop straight intoan escort or with easy modification? if not is there an upgrade u can do instead of escort ones? Quote Link to comment Share on other sites More sharing options...
rs2000escort Posted May 9, 2005 Share Posted May 9, 2005 i have some sierra struts im going to put in my car i dont think the struts will blot in but if you take the whole hub of (disc etc) and bolt it up to you escort strut witht the sierra brake calliper it will work thats what im going to do - well it should work :s Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted May 9, 2005 Share Posted May 9, 2005 what are u planning on doing with the back? let us know what happens Quote Link to comment Share on other sites More sharing options...
rs2000escort Posted May 11, 2005 Share Posted May 11, 2005 the back i have an aussie cortina diff im fitting keeping it leaf and drums ay btw you coming to the cruze dis weekend Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted May 11, 2005 Share Posted May 11, 2005 is it this weekend?? umm ill see i mite do mite not.. gotta sort my car out i mite have to catch up with u some other time to see what you have got as a set up Quote Link to comment Share on other sites More sharing options...
RT Posted May 11, 2005 Share Posted May 11, 2005 Sierra struts won't fit in an escort. They're totally different and the offset is wrong. Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted May 11, 2005 Share Posted May 11, 2005 is there any kind of upgrade u can reccomend rt? Quote Link to comment Share on other sites More sharing options...
RT Posted May 11, 2005 Share Posted May 11, 2005 Yes, Capri struts... If you find a 2.8i S then you get Bilstein shocks, vented discs and 4 pot brakes! But you won't find any! I havn't. Realisticly unless you plan on serious rallying then Bilsteins are not going to do fuck all. So if it's just a stronger strut and a brake upgrade then just grab a set of 1600 capri struts. Mk1 capri will bolt straight in MK1 escort and MK2/3 to MK2 otherwise you've got the imperial to metric to sort out. Not too difficult.. If you want 4pot brakes find some Austin Princess callipers, they bolt straight on standard discs and make a massive difference!! If you run em on a vented discs then you need to get a spacer plate to spread them out. Quote Link to comment Share on other sites More sharing options...
