Posts posted by nzstato
7 minutes ago, WhangareiKE70 said:
The alloy is like 1.5mm or something, but it’s alloy so should be easy. The stainless is about the same, so might be a bit of a struggle.
I guess I could just get it as a good tool and give it a go, if it’s no good then I still have a bead roller.
Alloy will be fine, stainless may struggle. If it tries to flex on you I've seen RHS tubing welded to the side of these in a 'C' to stiffen them up.
The come with a set of differing depth rollers so it also depends on how much metal you want to move.
I have one of those style of bead rollers. I 'think' the std roller is 2". You may be best to make up something to but against your pipe to keep the bead concentric. Heaps out there about how guys have add stiffening and modded these.
6
If the wallet would support me I'm keen on the Clipper, but may head down and see if the A35 is within reach...
13 hours ago, Muncie said:
I want to build nice compact looms that can maybe be tucked away a bit easier than a stock one without old crispy connections.
Ive always managed to get stuff working but yeah no more bullet terminals time to up the quality and water resistance.
Working for Rocketlab spoiled me.....
You work for Rocketlab? Guy I went to school with is VP of propulsion, lucky bugger....
I think @danger knows the spot I'm talking about. If you take a drive out the back of Palmy you'll see a whole bunch of 80s/90s mazdas slowing rotting under a tree. Been a long time since I've been out there and have since lost touch with the family.
Also, can you unpick the panel to work on it off the car? Would make the job a whole lot easier...
4
34 minutes ago, NickJ said:
I will quit my job and complete a 5 year panelbeating apprenticeship if it saves me one day of sanding bog, this is the extent of my hatred towards that satanic dust
I'd suggest sorting out the damage on the arch first before tackling the broader area of the panel. With the look of that arch it'll be pulling the rest of the panel hollow and you might risk over stretching the center in the effort to get the line back.
22 minutes ago, Bling said:
House finish came up really nice!
Hate to say it, but the mis-matching of timber levels on the steps makes me sad. Though they may be temporary, if so no worries. I'm a stickler for details though and it gave me a mad twitch.
Good job either way.
On the side of the steps? Yea, the top boards are close to cover up the framing timber behind, kind a rock and a hard place with what we could do to make it functional and attractive.
If you line up the jet in/exhaust out flows like in the diagram you dont necessarily divert the flow as most will pass through with some minor turbulence for your engine cooling needs - need to match inlet and outlet pipe IDs. The aim is to mix a the engine hot water outlet with a portion of the raw water to supply water inlet at your thermostat temp (I found a thread which suggests 83deg for holden v6).
Have you looked into fabbing a mixing tank? Its the best way to try to limit temperature surging in a raw water application
Choice, another trick is to mix dry ice in Acetone. The dry ice will sublime and leave the acetone at -78, not as cold as liquid N2 but with a higher head capacity it will suck the warmth out of anything.... extremely dangerous so only under adult supervision kids...
This is the TM pic, its currently sitting in my sisters garage in Invercargil till I can get it up to me.
I'm figuring its going to be pretty simple, main query is if there are any hidden grub screws/pins if I have to pull the quill to replace the bearings.
The bandsaw is the same as this model (https://www.trademe.co.nz/a/marketplace/building-renovation/tools/power-tools/saws/listing/3211603883?bof=Rd0yoNg7 ) but is in very clean condition. Its at my dads but came from wifeys grandad who was an engineer for F+P. He did have an even larger Tanner drill (except it had a nasty repair) but another family member took that.
7
Does anyone have a Barry source for old Tanner engineering gear? Manuals or technical drawings? I've acquired a HD band saw and a drill press for a song, seem to be in good nick but want to refurb the internals to have em last another 50 years...
Just got Council contribution fees for the subdivision, works out to be ~10k....
In terms of supply issues I think we've gotten off pretty light, the only minor points were:
The exact model of heatpump wasnt available, went for a similar unit at close to equal price
The exact carpet was on backorder, went a shade lighter which was in stock
Doors were 2 weeks late
Tilers were in short supply, put final fitting away a week.
Pretty minor compared to what I hear described....
And the debate continues.... are the grooves really to 'breathe', the increase in surface area would be marginal.
Final touch ups this week (I see alot of post it notes everywhere) and have finally been able to lodge title. Was suppose to be a month ago but hopefully that doesnt hold us up.
Old Lathes and machining shite
in General Car Chat
Not machining but metal forming... recently bought english wheel on its way to me. All 400kg of it...
