Had an unfortunate meet with an ugly curb while traveling round a nice sweeping corner on the way home from work, curb has accepted full responsibillity but left me in a pickle.
i bent the lower threaded tube on my BC at the weld point, bent the stub axel and think the lower arm is a lil out of shape. left hand wheel is sittin in about 10-15mm.
what im wanting to know is......
:axle has a 85mm bolt spacing which i think is the same as a AE86 please correct me if im wrong, so i should be able to cut the bottom of a strut and use??? is there much variation in stub angle between yota struts?
: the lower arm measures roughly 305mm from center of pivot point to center of ball joint. Any ideas on compatible arms.
if anyone has a busted AE86 BC with a straight lower case hit me up.
cheers
