Thought i better start a thread on here for my project. I've been chipping away at it for a while now, when i bought it it was mostly stripped except for the running gear which was a 1300 escort engine. i spent a few months cutting out all the rust, i've never done any work like that before so i've just been learning as i go, and my welder is sh** which makes it a bit harder but im getting there. i've got a 2.0 litre zetec engine mocked up in it at the moment, i've also just picked up a megajolt ignition and a set of quad carbs from a yamaha R1. I've started making a custom exhaust manifold which is coming along pretty well. This combination should be good for about 150-170hp sitting in my shed next to the car is a set of mk2 cortina front struts which need to be modified to fit the anglia and converted to coil-overs. (does anybody have some second hand strut inserts from a mk1 capri spare??) i also have a type-9 5 speed which will eventually make its way into the car but for the moment it will only get the 4 speed as i can't afford to do the 5 speed conversion at the moment. for the moment the diff will be standard but i also have a disc brake LSD from an EA falcon which will get shortened down when money allows and the anglia diff breaks most of the metal work on the body is done, and i am hoping to get the car running by the end of the uni holidays so i can get it from new plymouth to chch. this is when i first got it (looks similar to now overall) with the zetec with the new headers tacked up long way to go yet, its nearly ready for sanding down and shooting in primer to start the tedious body work... still got to modify the sump, fabricate a water rail, rebuild some decent engine mounts, finish the exhaust, build an inlet manifold, hook up the ecu, tune it, modify the struts and suspension, sand it, primer it, fill it, paint it, cert it, wof it, and then enjoy it
