Taistorm
Everything posted by Taistorm
  1. And down to the steel:
  2. Getting through to the bog:
  3. So kind of changed plans, well more so added to what we are doing. As this is being brought back to NZ shortly we decided we are going to address all the rust to make things smooth sailing through compliance. I spent most of Sunday with the wire stripper peeling back coats of paint and bog to see what we are dealing with. Starting of with the rear quarters and sill as there were signs of repairs here by the previous owners. Here's a photo dump of what I got up to.. Before:
  4. And the engine looking right at home... The clutch and flywheel assembly is fitted now. So next we continue with the assembly, alternator sidemount needs to get fabricated to clear the chassis rail, attach the other ancillaries, remount the fuel system components etc. Looks like i'll be getting some custom MCA coilovers made up for the front as well. This way we can achieve more low as it is currently sitting on its bumpstops and there is no suspension travel so would bottom out everywhere as is. We will probably put off the interior retrim until i'm back in NZ now. Cheers, Tai
  5. I tried to get some better picture of the engine bay paint today but it is really hard to do it justice. Also I wasn't able to get it out in the sun so hard to tell its full extent/sparkleness at this stage but here's what I got. Gotta love some 8 year old girl fingernail paint.
  6. And a teaser for the final product... I'm dropping in to check it out hopefully on Tuesday so i'll get some better pictures then. Haters gonna hate here //oldschool.co.nz/index.php?/topic/44085-tai-scamps-mazda-1300/ Chur, Tai
  7. So got some pics from the guys at the shop yesterday... Base coat laid out.
  8. Engine bay finally sitting in primer now.. Also picked up a bosskit for the steering wheel. Just got a SAAS unit as not to keen on shelling out $200 for a nardi one. So hopefully the engine bay will be painted this week then reassembly can start. Will also look at fitting up the steering wheel sometime this week. Small update but thats it for now. Cheers, Tai
  9. I've also started restoring the standard rear taillights as they had some overspray on them and the lenses were super cloudy. With the left side I have sanded (and wet sanded) to try and cut it back as well as running some polish on it. With the right I have only cleaned and used polish - tested it out to see the different finishes I can achieve but I'm going to go over them again, I also need to do the outer lens sections yet. Huge improvement so far though. Before: After: And here's a picture of the old sleeping 1300 ready to be awoken. What's next? Final assembly of engine and drivetrain then installation > Fit cooling system and thermo fans, pressure test and check for leaks etc > Finalise and fit fuel system, check over > Fit oil cooler and lines, check over > Mount electric ancillaries (starter, battery, alternator) and wire up > Finalise and check over front and rear suspension setup (install blocks and traction rods), set ride height > Fit brake lines and check over brake system, install pull type handbrake setup > widen and weld up rear outer wheel arches. All of this will be sorted over the next month then it should be ignition wiring, base tune and exhaust then ready to fire up. It's getting so close, excitement is through the roof! Chur, Tai
  10. Next phase of the build has begun, i've also started tidying up a few bits and pieces in anticipation. This is what I've been up to so far... Cleaned up the old centre console, ready to be fitted. Fitted up the CAS cover and Inspection plate.
  11. Thanks for looking, Tai.
  12. Hey Everyone, Last Sunday I was lucky enough to fit in a quick outing to the local Datsun Clubs, Datsun Day meet here in Belmont, Perth Western Australia. I was only there for about 20mins as I had a lot on that day but was able to grab a few quick snaps. Was a pretty awesome turnout with plenty of Z cars and early Dattos, even the odd Hakosuka which is the first i've spotted in the wild (I think it is a gt2000 mocked up as a GTR though but still dope regardless).
  13. Also MKIII for the front seats. Managed to pick up a pair of these cheap as chips bro. They look worse for wear but it is really only the bottom cushions that are torn and worn and the rest is dirty. Went to speak to old mate about getting them re upholstered today and he reckons he will have time to do them in about a month so stay tuned for that. Besides this, things have been slow. The guys at MotorElite have been flat out with the build up to WTAC preparing their FD that they havent been able to put any time on my 1300. Now that it's all finished things should get cracking again. Tai
  14. Not really a real post but have picked up a few more bits and pieces... Custom CAS cover and inspection plate cover from Kustom Cuts. Top bloke Mark sussed it out, will also be getting his repro r100 Garnish & tailight conversion setup down the line.
  15. I'm a big fan of the 240z mustard. I reckon an r100 would look awesome in that get up!
  16. Exhaust tips be gone! Much tidier now but still pretty meh looking. Maybe i'll get it red done one day but probably not. Sounds and looks sooo much better now, doesnt have that awful drone but still a bit too loud for my liking and has a bit of a rattle at higher rpm. I had done some measuring and did the rounds today to see what I could cook up suspension wise. There wasn't alot of options in the way of 'off the shelf' kits bar the usual 'sports low' springs through various retailers and coilovers through a few US websites. Was going to get some 'sports low' springs compressed and some shorter struts suited for a volvo for the rear then reindex the t-bar, add some shorter shocks for the front plus install an adjustable panhard rod however after pricing it all up id be looking at around the $1200-$1400 point and this would also sit the chassis rails around 100mm. Decided against it as it's a cheap daily I don't want to throw a lot of coin at, plus would rather this be kept a little bit higher for daily duties. Instead i've put some Lovell lowering springs on order which will hopefully drop it between 30-40mm which should still remain captive in the original struts and wind down the front end. It will handle like a bag of shit and it will probably bottom out everywhere due to lack of travel but fuck it. May also have some 14x6 (or 7) Enkei Gold 92's in the works but will see if it eventuates. Also I gave it a good clean today and tried to cut and polish it but the polish I had wasnt really abrasive enough so will look at it again another day. Removed the upper hatch wing to clean up the appearance, looks like it is worth around 400-600AUD as well so will be going up for sale. Had a look at sorting out the hunting idle. Unleashed on the vacuum lines and intake area with some carb cleaner but no dice, it all seemed ok. Will have a look at the iacv next. Cheers, Tai
  17. Yeah will have a look over the vacuum lines first of all. Coolant level is good but I think the thermostat is fucked as well as temperature barely rises so running cooler may also cause issues with the iacv perhaps? Looks like that rear hatch wing is extremely rare and i've got a lot of interest over in the US for it so might be able to make some coin off it! Jeah
  18. The disgust is real. I will be taking an angle grinder to them tomorrow.
  19. Spent a few hours today cleaning up the bumper/side strips and front lip. Scuffed them back and threw some coats of paint on. I didn't fill/smooth out all the little chips and scrapes but definitely looks 100x better. Unfortunately I was having problems with the plasti primer when doing the passenger side bumper strip and it ended up getting pretty bad orange peel. I might look at redoing it at some stage but meh. And here's some pics that make the paint look awesome. I'm going to give it a cut and polish tomorrow. Will look at repainting the other garnishes and trim pieces sometime soon as well. Also i've discovered a small problem, the engine hunts idle when sitting. When it's cold it is much worse but holds ok-ish when it's warm. Having a quick google it looks like it is common problem resulting from the IACV seal being worn or perhaps vacuum line problems? I've just cranked the idle bleed valve out a bit more for the time being to make it more driveable when cold but will look at sorting it out soon. Chur
  20. More pictures off the potato.
