just joind this site
i gta 78 hunter mint condition jut rebuilt the engine 500kms ago runs sweet
got wiv blown head gasket indicators didnt work wheel cylinders gone, pads gone, no wof no reg, all completly standard now it got :
Head welded, plained and fitted with new gasket
carburettor reset and adjusted
pull off springs re adjusted
new pads
new rear wheel cylinders
crank leak repaired
exhaust stopped smoking
rear bumper refinished
water leak fixed
new thermostat housing and water pump
new radiator hoses
new spark plugs
engine and cooling systems flushed
autogauge gauges installed (water temp, oil pressure, volts,vac/boost- (dash mounted))
type R 5" tachometer installed (dash mounted)
13" Cheviot modgies with brand new bridgestone 185/60/R13s
New front suspension ball joints
painted rocker cover
new gaskets
over heating problem solved
good oil pressure and no blow by
New air filter
New oil and oil filter
braked bled
aftermarket water temperature sensor installed and oil pressure sensor installed for autogauge gauges
bonnet cable fixed
choke and idle mixture reset
timing corrected with timing light
indicators fixed with new switch
