Posts posted by HighLUX
https://transact.nzta.govt.nz/transactions/ConfirmRegisteredPerson/entry
Bang your deets in and it will tell you if its still in your name
@Mop Head knows all about these
Rookie Daves diesel mobile doggin unit
On 20/03/2024 at 11:29, Bling said:Teenage is first car shopping and said he wants a Primera because they would look good modified, showed him this and pretty sure it was his first loooong whistle.
Pity P10s are unobtanium now
- 9
Id quite happily get on a small bike and ride top to bottom of the country. Yeah you can take side roads to limit the death but the death also makes it exciting and because you are going slower you can average more beers per km
I think iv compared TF vs TS barrel before and maybe the port timing was a bit different on the TS
Yeah keen on SW20 rad size and quality review. Iv been eying one up too
What have you done to your TF @SOHC
My wheels have the center sandwiched between the barrels so it was extra cunty to get them to seal but I got there eventually although a couple have developed a slow leak after sitting for a couple of years so il revisit it once I need them road worthy again. From memory I scuffed the barrels with a wire wheel on a grinder and lots of brake clean before going to smoo town
Scrape it all out and run a bead round the join. Smoo it out let it dry and then do a 2nd bead/smoo over the top of that.
I used sikaflex 291 because thats what I had lying round and it seems to stick well to the alloy of the bands
Whats a spray on grey underseal thats a good match for whats factory applied to a 2000s Toyota? I hit something on the road that made a bit of a dent in the floor pan and scraped the underseal off. Panel smashed it good again but need to get some underseal on there to make it look factory again before going for a wof
TF is 6 speed too. I feel an AG climbs better than a TF with the lower seat height. If you can keep traction then it just keeps chuggin
Just needs a couple of LED whippy boys on both sides of the front bumper and a kenworth windscreen banner
This guy exudes Erics dodgy gold mine
Can you count input turns to output turns to work out ratio?
Surely you can find a 140cc pitbike dumped in a reserve somewhere local to you after a whooliboi police chase and make a big bore adv CT
That Hansen fitting will be fine with the heat. I've run them on the back of a fireplace to hook up a wet back and they didn't even go soft with 80 degree water running thru them
22 minutes ago, HumberSS said:
@HighLUX I think I'm retarded. Can't work japan-parts.eu ... Need to find plug leads part number also... Hints on how to use search function or direct me part number to if you are feeling inclined.. chur
Select japan since it was a jap market car then year and model then engine type
V6 petrol surfs are a bit shit and will use all the of the pertol. 90s surfs like to get rusty especially in the bottom of the doors. 1KZ surfs have an appetite for heads/gaskets like a M series. Depending on budget then a 2.7 petrol surf would be the best bet. Do you want 4wd specifically or just a load lugger
This fella on FB knows how to farmbike
East Cape ride circa 1987
- 6
Jamies 86 Hilux Sr5 bargain basment build with added boat anchor
in Projects and Build Ups
The radiator situation is proving to be a bit of a headache as the available space is minimal thanks to the S/C electroclutch pulley taking up alot of space. where you would ususally plonk a nice thick rad for plenty of cooling.
Did a bit of mocking up today with a couple of radiators I had kicking round its looking like a unit from a GA61 Supra will juuuust fit with a pusher fan on the front of the radiator. This one is pretty beat up and manky so will see if I can find an alloy option
