Done quite a bit of work on the escort over the xmas holiday, taken it for a wof(just to see wat it needs before a cert) failed on no cert, brake imbalance, draging drum and inner rack end. nothing bad so im pretty stoked. will fix all that over the next couple weeks, get the carbs tuned(for emissions) then go for a cert finally.
Here are some pics...
Last of the rust(other than passenger door) delt with.
235 eagers dont really fit without rubbing away to nothing being that low, look cool tho
Engine bay got striped back, primed then painted. all the loom was redone for the 2L etc...
Shifter hole moved and gearbox mounts welded on(see how they go for a cert)
Engine in and running with a new exhaust to quieten it down. sounds good...
all interior in, vinyl died all the seats and door cards, turned out mint
Didnt turn out too bad, just needs a panel and a paint to finish it off(and the c pillar trim if any1 has some?)
Sweet to finally drive it even if its not legal(yet)
The black escort is now siting behind the shed with no engine or anything else for that matter, if any1 wants an escort thats got a "couple" of rust problems, a welded diff, front suspension and not much else, hit me up(going cheap)
