Everything posted by KKtrips
I would check to see if it was actually classed as a 5 seater originally. If it did then it would have had 5 seatbelts from factory as that was the requirement in NZ from 1 November 1979. Officially - if it only ever had 4 seatbelts from factory, I would look at getting it reclassed as a 4 seater and also get your cert plate changed so it is compliant. Unofficially - it is unlikely to cause a problem for you unless someone was going over your car with a fine tooth comb which would not typically happen unless it was going through Low Volume or Entry Certification. The fact it has been through certification already says it passed a close scrutiny check once before so probably would't get picked up.
FYI - returning a vehicle to stock there are 2 processes are called a Full Return to Standard or Partial Return to Standard Both require a certifier inspect the vehicle for any modifications that have been removed, and that they have been removed appropriately and safely and also that there are no subsequent modifications since originally certified. If the answer to both is yes, then the certifier will remove the plate and get in touch with LVVTA to advise a full return to standard. LVVTA will remove the reference to the plate out of Landata or if it is a partial return to standard then LVVTA will print a revised plate and send to the certifier for them to fit. Both require to pay the certifier for their time spent inspecting the vehicle, completing any paperwork and attaching the revised plate (if necessary) A partial return to standard also attracts a plate reprint fee from LVVTA. Keeping in mind that if you are changing a gearbox that was originally changed from Manual to Auto before certification and now going back to Manual and the replacement gearbox is not the same as the original OE manual gearbox, then a full recert is required, because it is not returning to stock, it is a further modification.
I'm not sure its ready for my level of sarcasm.
LoL
As stated above, it's not the lift that kicks a 4WD into requiring cert, it's the additional mods that come with it.
Yes, the issue will come about from the angle of the steering drag link will be steep enough that you will probably need to fit a longer/adjustable drag link. That does require cert.
Grab a copy of the threshold document. It lists all the modifications that don't require certification in one handy location. https://lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf
Are they live front axles?
How do you decide that a vehicle you are inspecting for a WoF requires cert.
It's not a 50mm lift that requires cert. It's how it is lifted that makes that determination.
I haven't checked a WoF for 15 years, so I'm outta touch. Maybe @alltorque can correct me on the way things are done these days.
Also, don't worry, I "argue" with people all day long. It's normally only the ones who take a highly unlikely modification and apply a requirement in a hypothetical situation that doesn't even apply to their own vehicle just to win an "argument". It's those people who wig me out.
Normally a WoF inspector would not need to ask the question provided the vehicle was not extreme in height and the vehicle handled and performed as expected. If their alarm bells were going off then it would be up to the owner to prove their vehicle complied, it is not up to the WoF inspector to prove it doesn't. A WoF inspector has a certain amount of descretion, that's why they have to had been in the trade for 4 years prior to getting their authority.
Yes edit: for clarity, must be catalogued by a reputable suspension manufacturer, not a list of part numbers on some random spreadsheet on an obscure website.
I get calls about this kind of thing several times a week, a vehicle owner will ring up complaining that a WoF inspector has incorrectly interpreted a requirement telling them they need a cert. From the information provided by the vehicle owner we can determine the WoF inspector has correctly interpreted the requirement and I can explain this to the vehicle owner. we can determine the WoF inspector has incorrectly interpreted the requirement and I encourage the vehicle owner to get the inspector to call me and I can explain it to them When the WoF inspector calls I can explain the requirements to them, sometimes it turns out the information provided by the caller was incorrect or an important detail was missed out of the conversation meaning the WoF inspector was actually correct and I encourage the WoF inspector to then get the vehicle owner to call me back so I can explain it to them if needed. We have pretty good bullshit detectors here and can get most of the necessary information out of the vehicle owner pretty quickly unless they are intentionally hiding something knowing it will change the answer, a call from the WoF inspector usually clears that up though.
No I don't sorry. FYI - in this instance, direct replacement means an unmodified catalogued part for the vehicle. eg: if you fit R32 Skyline springs in an R31 Skyline they may fit but they are not a direct replacement.
What's vague? I can clarify. Also only the bits in yellow are changed from previous threshold doc.
Hey Leon. Anything that has been previously certified is accepted at face value unless there is something that could be considered not fit for purpose or if it was unsafe.
K-Trips 1982 Holden Commodore VH Build Thread
KKtrips replied to KKtrips's topic in Projects and Build Ups
I think this might be a better pic of the crossmember. Discuss here - https://oldschool.co.nz/index.php?/topic/26290-k-trips-1982-holden-commodore-vh/- 67 replies
We'll talk about a spanner in the works. Some guy named Covid (sounds Dutch) threw a bit of a curve ball. Seeing as my lockup was the other side of town and further away than I was allowed to travel. This thing has been on ice for 7 weeks. Anyhow first day back on the spanners netted some progress. Super stoked with how the crossmember and rack turned out.- 67 replies
- 25
KKtrips replied to johnnyfive's topic in Upper North Island Region
mmmmmmmm, masturbation -
Holy shit man, I am exceptional at procrastinating -
Interest expressed, attendance dependent on my use-less-ness -
Get used to this
Oh wait you mean supermarket? yeah samesies here. BOOKED SOLID.
