So this is my first project and working on cars is realativly new to me, but i want to try do all the work myself so i decided to take a closer leak at the oil problem. We could visible see that the water pump shaft have a fair bit of play in it so i thought id pull the fan and belts off to get a closer look,
Firstly i set up,
Then i removed the fan cover then the fan and the fan clutch and the belt and the pully,
And so i was left with this
its was quite obvious the water pump was fucked so i decided to replace it. Amazingly enough repco actually had one instock.
Because i have never done this before i went to the libary and photocopied the manual's how to install a water pump section.
First i had to drain the radiator, this was quite messy
Then i undid the old pump. and scraped off the old gasket which was completly fucked. Then i degreased the block side of the pump. I gave it a good clean then a very light sand.
Fitted the new pump.
I then re installed everything and refilled the radiator with water following the correct way. Initial drive, there was still a tiny bit of spray but i hope that was just from the degreaser on the parts i re installed.
this is just a shot of all the crap we've ripped out so far. Ive also removed the toe bar and the sound deadening out of the boot. I painted the mesh in the grill and one of the side bits where it was white instead of black. Its now black!
Cheers Grant
