Testament
Posts posted by Testament
  1. 20 hours ago, peteretep said:
    We get heaps of machinery Powdercoated at work, which has a really tough nice finish, but it is quite time consuming vs something like wet spraying. I saw some machinery those other day that had a really nice surface finish that was like wet spray but it was slightly textured and felt as if it would be a bunch tougher than your typical wet spray. Are there any painting types in between wet spray and powder coating? Google shows a whole bunch of gimmicky things so I can’t gauge what’s a real commercial solution and what’s not. This replaying to painting big 1 ton+ steel frames, to small 500g steel/aluminium parts
    We usually use carboline paints or altex coatings on stuff at work when we need to ask for specific paints and have really good service/advice from their application people.
    TBH the last one I got some advice on I was very surprised, inside of an atmospheric flash tank, total ball of rust inside just painted it in hope to get it to last 4 more years/total band aid didnt have much else we could do at the time. opened it up last year (after 4 years in service) and 90+% of the paint was there. there had totally expected the steam and hot water to have just peeled it all off like it wasnt there.
  2. read the rules for whatever sanctioning body you are going to be running under 5 times then read them again.
    there are many differences between manz/fia/nzdra/ihra/nhra/oranz  etc. etc. etc.
    alot of the time you can actually build something compliant to several but you have to understand the rules. height of the aforementioned door bars,  placement of backstays, relationship of main hoop to driver etc. can all be subtly different.
  3. adaptors dont straight up make the reading wrong, but certainly add to potential for other forces to come into play than just twisting. This can certainly cause incorrect/less actual torque to the fastener. a bit like installing dry vs various types of lubes
    reality is many cases you have to use extensions etc to reach certain fasteners, just have try to do your best to only apply torque and minimise out of plane/bending forces.
  4. 30 minutes ago, KKtrips said:
    Providin you use the correct fuel line, have no connections inside the passenger compartment and it must use bulkhead fittings at each end, it should be OK. But it must also be able to be inspected, so covered by carpet is a no go.
    so implying more of an allowance for race/rally cars with stripped interiors
  5. 22 minutes ago, ajg193 said:
    Seems that these days amayama doesn't take your money until they have confirmed stock.
    I'd imagine it is hard to keep track of parts in warehouses spread across probably 50 countries, especially when the car was made before the internet
    dunno, rock auto do it pretty well
    but yeah everyone else fucks it up
  6. I just put alloy spool of wire+ matching size tip in normal mig welder+handpiece. has rolls with different knurl for alloy I think/maybe/cant remember. Plus pure argon for shielding. It works acceptably but its suited more for thicker/structual type stuff because you end up with not enough heat to start with, or enough to start with but it gets too hot quickly. so difficult to make a nice job of anything that is only a short weld. Also you are relying on the arc to blast the oxisided layer off, which with mig means wire going so this also is a factor in shitty starts to welds unless you can run higher amps etc. (i.e. thicker materials)
    The other tip with using it in a regular mig is to keep the torch lead as straight as possible.
    I never had any issues with brids nests etc. just the aforementioned limitations of the setup
  7. I don't know what I'm doing/rookie Dave/this thread showed me how 2pac and Ive always put a little thinners in, just to get consistency right the durepox is too thick with nothing added. Not as much as if I was spraying it, just a little splash.
    But yeah, different paint, and I don't know what I'm doing with this stuff.
  8. Everyone ever says 4l60 goes in the bin if it's more than a standard motor. Just know you will be blowing it up and putting something else in, and if your ok with that well then it's your choice. If it was me I'd put my time and money into something else as you can't reuse clutch/convertor etc in Anything else after it's grenaded.
  9. Weird, did you use any thinners? Mayber the hardener has lost its mojo
    Only ever used durepox and often get the opposite issue of having to work real fast/brush turning to wood by the end of the job
    /Ling
  10. 1. most of them are resuseable - the issue is disassembly without damage - a heat gun can help here rather than prying too hard and risking gouging sealing surfaces
    2. if the hose ID/OD are right for the fitting it should be ok  but there is some potential for issues, so its up to you how confident you are and how critical the hose/connection is. The short answer is its not recommended by the manufacturers
    3. yes, but see 2.  as it depends if the fitting is designed to accept both types of hose/both hoses have the same ID/OD dimensions. Ideally better to have the correct end fittings for each hose going to a threaded connection in between
    4. there are lots of local sellers  NZKW, STA, scarles, cardwells, proparts, etc. etc. etc. the list goes on google is your friend
  11. how does the seat of the pants difference feel in the lower RPM driving round? the tvis intake does make 5?kw more in the low end which doesnt sound like much but is quite a bit when its only making 40kw total at those engine speeds. I'm guessing its not an issue because you dont drive a 4age anything like a truck?
