Posts posted by Abarth
Sweet cheers man, do you have a spare seat? Mine didn’t come with one and we’re looking to use the OG base and reshape it and cover it.
Your build is looking sick too btw, keen to see more about the Motogadget stuff as that stuff looks tidy.
Me and a mate had been looking for new project bike for a while, trawling through Trademe and FB marketplace.
This CB350 popped up as an unfinished project that the previous owner wanted move on to fund some of his other Honda classics.
Perfect tank shape and in the condition where we don't feel bad chopping and changing a classic.
As all good projects start, I picked up the bike in pieces, threw it in the back of the ute and raced home to check it out in detail.
Did a loose mockup and pretty much everything thing is there. The previous owner painted the frame which was a nice surprise, however for some reason cut off all the mounts and tabs for the the seat and foot rests/side stands.
Plan is to cafe racer it, clipons, rear sets and wider rims. Loving the OG tank colour so the blue will stay, we'll add the Honda wing badges like on my CB250k.
Decided to strip the whole thing down in order to get everything vapour blasted, pulled down the motor and that looked like it had been recently rebuilt as it has oversized pistons and the hone on the bore was fresh. The lower front engine mount had snapped off so we split the cases and will be sourcing a new one.
Also got started on the rims; Pretty old and rust so we’ll start again with these.
Current status:
@azzurro Are they Weber 152 made in Spain versions?
if they are it’ll be the progression holes causing the issue. Or lack of, there should be 4 or 5 holes but the 152’s only have 3. The 4th hole should be directly over the butterfly.
Have a look how many holes it has, they are under the bigger brass flat head cap screw on the engine side. One for each throttle body.
Edit, like this:
Jeeezzz, its been a while for this car!!
Finally got time to work on this after 5 years of sitting in a garage.
Did all the basics today, changed fluids, new hoses, new filters and got her running.
Chucked some new rims on, thoughts? I think I'll like them more when I convert the bumpers and trim to black.
Took it for a quick drive and fk me there a lot to fix on this car!!! Motor pulls strong however the car feels like its on skates, darting all over the road.
A quick look at the suspension and literally the rubber bushings have dry rotted away. Pulled the rear arms and shocks out so I can get them rebuilt.
Anyways heres a pic of its current guise
- 20
6 hours ago, Big Value Buddy said:
Jay Lawrence rules!
^This
- 7
Hondas been leaking fuel for about a year now from the fuel tank, it was a slow seep which was annoying and was mostly soaked up by the foam in the seat which stunk of gas. Also the pipes which share each side of the tank were blocked and leaking. Basically this tank has had hack after hack fixes with solider, JB weld etc...
Safety first, pumped exhaust through it for about 15mins to get rid of the petrol fumes.
Drilled out the old share pipes and mounted the threaded steel boss.
Leak came from under the mount bracket, didn’t have a spot weld bit so just went hard with a normal bit. Pretty mank under the bracket, no paint in there so wasn’t a surprise it rusted.
Welded up the holes but I reckon I’ll get the rest Tig welded as my Mig isn’t great at sealing up fuel tight.
Decided on painting it, need to strip the POR15 liner as it was fkd and coming apart in the tank so I covered the whole tank inside and out in stripper. Will be repainted in black 2k
I brought back 48mm Weber sidedrafts in my packed luggage from Ozzy a few years back, no worries
I scored some free BRZ seats to fit into the Punto however the BRZ seat mounts are a little wider than the Puntos
Are there any recommendations for anyone who could cutty cutty weldy weldy to make the mounts fit?
Mini Cooper S’s supercharger sounds so good!
When they are going they are actually awesome cars, handle mint and go reasonably fast. Interior feels big with the upright a pillar and dashboard.
Looks awesome man.
Great success on the water this weekend!
Did a couple of laps around the bay, initially she was running rich so dropped the needle down in the carb. Power picked up a lot after leaning the mixture.
Goes mint for a little engine, had three guys in the dinghy and towing two other guys in Kayaks, moved along ok. Went out to a fishing spot and caught a Kawai. Smoked it for dinner. Success.
- 34
Thanks fellas, they are really cheap on trademe, people seem to leave them for ages in the back of a garage then sell them in unknown condition.
Its hectic in the wheelie bin at full throttle haha
Runs a hearty 10:1 oil petrol mix so I got some Ipone two stroke oil, smells like strawberry when it’s running which adds to the lol factor.
Is this the next summer OS event; Seagull dinghy races? I can picture the spanies now.
Edit:
Video inspo!!
- 8
11 hours ago, tortron said:
Hot damn, bass boat flake on the dinghy plz
Cheers, the dinghy is two tone white and orange, hence the orange grips for the Seagull.
Forgot to mention these things are insanely well built, probably why they have a reputation for reliability. A lot of it’s made from Brass; the fuel tank, the whole exhaust pipe, pins, nuts and bolts etc...
Will test it out this weekend so standby for updates
Here’s a couple more pics!
- 8
After finding out it ran pretty decent I decided to strip it down.
Didn’t take any pics but the water galleries around the cylinder were caked with rust flakes. Managed to remove it all with a screw driver. Looked like old coffee grinds coming out of it. So much!
Also pulled apart the gearbox down by the propeller which had a 50/50 mix of grease and water in it. Replaced it with gear oil and closed it back up.
Made a new throttle cable from a bit of cable I had sitting round.
Oh yeah paint.. Lol
Got some blue 2k base coat and added holographic glitter to the clear for a laugh. Looks like a 90’s show car but shines mint in the sun.
Wasnt even sure the glitter would come through the gun but yip it definitely did!
- 29
Picked up an old British Seagull outboard off Trademe a couple of weeks ago.
This is a 1961 Century 100 model which packs about 4hp. Pretty rough condition dents in the tank and surface rust everywhere.
First step was to get it running as it had sat for many years and the sellers weren’t sure if it worked. Got it home, added fuel and first pull it sat there idling like a champ.
Stoked! Perfect for cruising round in the dingy for summer.
Next is paint....
- 18
Yeah man if I could borrow the kit that would be awesome!
I’ll send you a PM
Thanks!
Yip, driven a couple of manual ones, standard and modded.
Auto was actually suprisingly good, super smooth, the car as a whole drove really nicely. Excellent for Auckland traffic but wouldn’t be great for track duties etc.
There’s like a 10k - 15k ish price difference between and the AT one was tidy.
That was some of the appeal of an auto FD, that they generally haven’t been modified or thrashed. Knowing that further down the track I’d have to rebuild the motor and while I did that I would swap it to manual.
7 minutes ago, rotor_dude said:
All series 6 and probably series 7 will have oily turbos, just age, wear, tear etc
Your not going to get one without it really.
I wouldn't let it put you off. It just needs factored in.
Just something that will need done due to age of cars,
Same as rear pillow balls, series 6, most will need replaced, now series 7 getting to that age to, where 3/4 out of 6 need replaced
You won't get a perfect one now. Being 20-25 years old
You can't really avoid the cars because of it,
Unless someone has spent money reco turbos and new pillow balls.
Yeah no doubt they are getting old. Just don’t want it to shit the bed straight after buying it, especially if it’s turbos or a water seal causing the white smoke.
On 11/08/2018 at 09:54, rotor_dude said:
You take the trailing spark plugs out,
Not leading.
Results not accurate unless have rpm.
As it changes etc
Adjusted to 250rpm
But if there 3 even pulses, even between front and rear rotors, that's good start.
Would help if you gave all 3 readings per rotor.
I personally do a cold and operating temp compression test, for better comparison.
From memory, minimum compression
85 psi at 250 rpm
5.9 kpa at 250 rpm
white smoke on start up,
possibly the turbos, the oil seals have gone, letting oil into the intake side of things,
so overnight the oil drains to the lowest points in the inlet,
then on start up oil is in the intake and burns etc
check the y pipe coming off the turbo outlets, on Series 6 there is a hose and pipe you can remove and see if oil inside etc
Thanks man.
Could be right with the turbos smoking as from cold it smoked a lot of white smoke on startup, a good 2 min then cleared. Then starting it hot it smoked a bit too but cleared much quicker.
It’s a shame as it’s a tidy car, I’ll probably just steer clear and get a MT one anyways.
azzurro's 125p Pickup dyskusja
in Project Discussion
Sweet as. That stumble at low throttle is caused by the butterfly opening, taking in air and not yet getting fuel from the progression holes.
Needs that 4th hole drilled directly over the butterfly to fix. It’s like a 1mm hole drilled in exactly the right spot.
My 130tc has this exact issue and I’ve been meaning to get it drilled for ages.
