Posts posted by ~Slideways~
3 minutes ago, Nominal said:
Google photos links work for a few hours or so then go dead.
Ah, thats annoying. Cheers
3 hours ago, Willdat? said:
If I'm driving the 2GR model I get the same, if my wife is driving she gets <7km/L... It dorts well though.
Our GS350 is used for the kindy and school run, it gets down to 6km/l from the short runs.
Longer drives and it hovers around 9-10km/l
Did a trip from wgtn to Tauranga and it managed 13.5km/l with 3 people and packed with stuff.
I wonder what the hybrid versions do? Probably has much less boot space due to batteries though?
17 hours ago, rumrum said:
g pics don't werk
Should be good now, was working with Google photos at first then it stopped. Not sure why so uploaded instead.
18 hours ago, fuel said:
Pics no worky for me
Weird, they were working at first but not anymore. Have uploaded to OS now.
Took this off the road to deal with the rust on drivers side of the roof, it was worse than I thought under the bog job that the previous owner had paid a lot of money for.... that was probably 7-8 years ago now so I guess it lasted a while.
I decided to go all out and cut any trace of rust out of the roof then paint the whole thing.
Condensation is what gets to the roof skins on these so I sprayed lots of wax anti rust stuff in everywhere.
Decided to do something a bit different and paint the roof with 2 pack textured stuff, like Raptor liner but I used Novol Cobra stuff.
In theory it'll hold up to scratching branches etc, some sound deadening and I don't know...it looks cool?
Also stripped the front bumper back to bare steel and coated that too.
This is just after spraying it so its a bit less glossy once dried, in person it turned out pretty cool:
Also made up some brackets to fit the passenger WRX seat, Murphy's Law meant the last bloody bolt was pre-stripped, it'll have been like that the whole time I've owned it, no way of getting it out so ended up having to cut it open to get to the stripped nut inside and weld it back up.
Can't remember the sequence of things that happened but in a nut shell, multiple dyno visits and some teething issues:
- Had boost control issues due to heat melting a vacuum hose, tried extending the fitting by getting it braised but wasn't enough, then found that Turbosmart now provide fittings in their annoying thread and size that no one else uses or stocks. Used some of those to get it away from the heat. Added a bunch of heat shielding and some of that gold tape stuff.
- Over fueling in higher revs, theory was that the Xspurt 1000cc's have a single narrow spray pattern and the 1jz vvti has quite a wide casting/wall in the centre of the intake port. So the fuel must have been hitting that and just flooding the walls with little atomization. So I went back to 540cc Toyota injectors, from an ST215 with plug adapters to test the theory as these have the exact same 4 hole pintle cap jobby as the original 1jz vvti injectors. Should be enough for 300kw atw on 98, I originally went with aftermarket Xspurt 1000's in order to be able to run ethanol later. But that's much harder now that e85 is gone.
- The night before dyno booking the cam cover gaskets decided to leak like a sieve when I went to fill up on 98. Ordered Toyota genuine and did that.
Back on the dyno just before xmas and the injectors appear to have helped because now as soon as you give it any more than 10psi the clutch lets go. Looks to be limited to 450Nm, previously it didn't slip at more than 14psi, now it can barely handle 10psi. On the other hand it was probably also getting hotter than before. Drove home perfectly fine but made a plan to upgrade the clutch, which I had not been looking forward to doing.
Wasn't looking forward to taking the box out, because its in a chassis it was never meant to be so was expecting it to be a right bastard of a job.
Google tells me the R154 is 110kg?! I've done many myself but all probably half the weight.
So I bought a transmission jack, even my wife said I should after I said how heavy it was.
Turns out it wasn't too bad of a job to get out. Managed to get the driveshaft out through the two driveshaft loops without removing them and the only thing getting in the way of pulling the gearbox all the way back and off was the starter motor bulge hitting the tunnel.
Next time I'll unbolt the pressure plate from the flywheel to give a bit more room. Left it on because I wanted to see if it was possible for when it goes back in.
The piece of wood is tilting the engine back a bit with the jack.
I've now massaged the tunnel a bit with a hammer to help.
Managed to get the flywheel machined even though everyone is closed. Drews Automotive is closed but the guys a bloody legend, was not working and was going away the next day but still got it machined and tested the old pressure plate and the new upgraded one to compare.
Old PP was 1800lbs
New one is 2600lbs
Clutch plate is a 6 puck sprung centre jobby.
Old clutch plate had plenty of life left in it, just not enough
Fitted Toyota Genuine rear main seal and spigot bearing. Totally forgot I need to replace the flywheel bolts since they are meant to be torque to yield. Have ordered some ARP ones now.
I'm sure I've reused flywheel bolts before but for the little bit extra I thought I'd better change them since I don't know their history.
Aim now is to go for 300kw atw, should be able to get there hopefully, intheory the only thing holding it back was the clutch, which had previously held 260kw atw (for one run on the stock Toyota ecu). Bloody scope creep, this was meant to be running the stock 1jz engine/ecu/turbo....
Have been driving this everywhere, bit of a tidy up and a new wof.
Took the Semi's off and put the super cats back on, man what a difference the tyre walls make it feel like the tyres are flat. Still fun but easy to out drive the grip now. Shame the semi's are so fckn loud, louder than the worst mud terrains I've had!
Haven't had a chance to do anything else on the Speeduino yet, needed it as the daily while working on other cars.
Out of interest I unbolted a spare 1.6 exhaust manifold to see how bad the collector was to see if they were as bad as Roman's ones.
Yes they are.
Welded on the inside with a thick bead which is choking it down from the head port size:
Look at how much the tube is crushed to fit into the collector!
From the inside it doesn't look so bad because you can't see the crushed bit, but based on the outside, they must be bottled necked heaps here? Why didn't they just make the cone bit a little bigger to avoid crushing down all four tubes?
Bet if I made a better manifold it'd make at least 2hp across the board.
Fixed photo. Saw these in Naenae.
- 7
Watching with interest, I remember my old '83 ae86 was stock standard when I got it, even had the intake crossover pipe over the radiator, that thing had so little torque that even gravel roads would require higher revs to break traction.
I remember it was a thing to remove the TVIS butterflies for "more top end", I never did that but I imagine it would make the bottom end torque become a black hole of nothingness.
I had a stripped out ae92 Trueno, no sound deadening, no carpet, no stereo, motorbike AGM battery, seats removed, racetech drivers seat, removed sunroof with alloy panel, plus extra weight of turbo stuff.
Metal Recycler weighed at 920kg.
I know you meant AE70/85/86 chassis, but you said AE's so there you go. Don't be a racist.
12 hours ago, tortron said:
Watching various motorcycle touring/adv content. They all complain about how tiring it is to pick up your bike, and that in turn makes you more likely to drop your bike again.
Mate just ride a sub 100kg bike.
unfortunately it wont be as 'light' as my touring bike which i could shoulder fully loaded across rivers and up staircases, but will be close lol
Have you watched this guys stuff? Pretty cool.
Oldschool spotted?
Still chasing this misfire, currently have injectors out, which were new xSpurt 1000cc's when put in some time over a year ago.
They were tested and it sounds like one was a little iffy on a low pulse, but was then fine which is frustrating. But it does actually match the intermittentness of the misfire. I'm not sure its enough to explain the behavior I'm seeing, but maybe since it only happens at idle/low throttle cruise which would be a pretty low duty cycle on big injectors, it could fit.
Getting them ultrasonically cleaned, if that doesn't do anything then maybe I'll just have to buy one new injector and hope for the best.
Haven't had much time to spend on this but have tested the Speeduino in the car a bit more. I had a problem where it seemed like it wasn't reading the trigger signal but have it working now.
When its connected to the car it reads:
- Air temp, with a generic Holden/GM sensor.
- RPM through the factory loom
- Water Temp
- MAP (vac line to speeduino onboard sensor)
- TPS (BMW one not on the car yet)
- Injectors duty cycle
I still need to sort out an AFR sensor and controller. Maybe I'll just use the one off the 200sx for now.
Previously it just cranked and didn't start but I was happy because it was communicating with sensors etc, this time it actually fired for about 1 second and got up to 1500rpm then died. I view this as a big success though! It does stuff! Even without the TPS fitted since I found I need to remove the throttlebody to get it off the shaft, ran out of time/daily driver things.
I can't tell if the fuel pump is running because its so quiet. Maybe it's just not getting fuel.
Also, much thanks to @Roman for printing this adapter:
- 8
1 hour ago, Yowzer said:
Yeah man it goes good! I killed the motor but that was due to deliberate abuse, chucked a new motor in it and it's back up and running.
For the price I think it's worth getting it from Supercheap tbh
Good to know it works well, yeah probably best to just get it from Supercheap. Last time I looked, no one was doing that type of ratchet for some reason. Maybe because they don't fit with the whole one-battery-for-all thing?
On 30/08/2020 at 22:01, Yowzer said:
Holy lols that is my AliExpress ratchet
Is it any good? I was thinking about getting the SCA one but if its the same as Aliexpress I might as well get that. Do you still have the seller details?
2 hours ago, BlownCorona said:
i dont see any reason you couldnt make one. 3d printed ones can be purchased from someone on the NZMX5 Facebook page, but i cant remember who. i also got banned from that page for consistently pointing out that one of the mods, who is also on oldschool, advice is always horrible and wrong lol.
I was thinking I could make something out of aluminium but a 3d printed one would be easier if the guy on NZMX5's is doing it, I've joined now to try find them.
Lol, that's a bit weird about being banned.
17 hours ago, BlownCorona said:
bmw e36 (or pretty much any bmw) TPS is popular, several options for mounting it to the mx5 throttle
I literally just got back from Pick a Part with a BMW one! Cheers though.
I was actually hoping to find a Nissan one which is supposed to be a good fit without an adapter. None there so got the BMW one based on the PnP kits.
I'll see if I can make an adapter or if I need to get one 3d printed.
27 minutes ago, V8Pete said:
/Emergency exit?
True, could be or also a bit more head room.
Holy crap that's amazing.
Interesting that they all have a sunroof too.
It does things!
Firmware successfully updated with speedyloader:
Tunerstudio recognises it and when I set the map sensor correctly it reads a change when I blow into a vacuum hose:
Connected to the mx5 loom it powers on and the LED’s flash when it cranks:
Next I need to go to Pick a Part and find a suitable variable TPS that’ll fit and maybe a generic Air temp sensor and see if it will fire.
Then decide what AFR sensor to use, could just take the one out of the 200sx but to be honest I haven’t been impressed with it.
- 5
Like a glove:
From the top you can barely tell, which is the side you can see. Just the extra screws on top and the USB cable out the side:
Mounted on pc stand off screws:
All in there with hole in the side for the cable:
2 hours ago, Adoom said:
Can you get another case and stack them?
Maybe... the standard one can go on top although the bolt holes don’t go through. I’ll probably just space it out or make a new bottom plate.
Trying to find out what type of resistor and diodes the adapter needs but Other than that it’s altogether.
Will need to modify The standard ecu case as it’s too tall.
Romans 2005 Toyota Echo
in Other Projects
Does the weight difference still add up when you've added all of the extra turbo stuff?
Really interesting idea though...
