Everything posted by ProZac
Really sweet ride man. A customer bought his genuine Bellet GTR into work for me to see the other day, what a freaking cool car!
The car? Hell yeah man, runs mint, will shout you a skid . Nah, been doing uni work all week, but im now on holiday, so i only have my chronic slowness at doing everything to contend with . Come get that crank you lazy bastard. Need any other bits? I scored another DOHC motor the other day, this one isnt even fucked, w00t.
Looks all good Cheers man, much appreciated.
WTF? Where did my project thread go? Can anyone out there in moderator-land have a look into that for me? kthx.
Well, between holding down a job and studying at uni, the car hasent really gotten a look in for the last month or so. Got some jobs done today though. Gave up on the pie section idea, and went for pre-made bends. Tacked the pickup together and made a support for it half way along its length. Will weld it completely when i get my tig welder in a couple of months (saving is so hard!). Cut the side profile for the sump from some card, and put it in place to see how everything will clear, got it right first time for once! Clears everything inside the block nicely, and looks like i'll be able to get the engine about an inch lower than initially thought, which is awesome. Now, the important bit, pictures! Got some sweet hub-caps for the steels, which will be widened: Went and picked up the diff from my parents, its from an isuzu piazza. Should fit without to many issues. Has disc brakes, but no LSD alas. Cheers to Chris (CUL8R) and Dave (Brock-Lee) for this .
yeah man, ex lancer 1600 5 speed, came out of the same car as the motor.
What did you use to clean up the pistons man? Lookin good.
Hah! thats fuck classic 4 speed should work, but you might need to modify the lockout plate a bit.
Whats the plastic bush on the ball on the bottom of the knob like? Their often totally fucked, or missing altogether and make a pretty big difference.
Im a student, so it'll take a while, but i'm dead set on it. Your more than welcome to have a play once i get setup .
Yeah, i rekon a cheapy chinese one will be fine for the infrequent use i'll give it. Probably going to go for one of those mitech 200's, AC/DC, a few adjustments and what not. $1500 including torch and foot control.
Very sweet. Got some mad skillz there. What tig machine have you got man? Saving for one myself at the moment.
Not to bad, will work, but i've changed the design again to get it even closer to the motor, so the whole motor can sit lower. Going to do it with pre made bends also, instead of my mickey mouse pie bend idea.
Holy crap that new welder is a joy to use, seriously outstrips my meager abilities, but is miles and miles ahead of my other little one. Got the pipe together today, looks good after some grinder and file action. Welding didnt look to shit hot before hand, but i made sure it had plenty of penetration. Once the flange is on i'll check it for leaks with some meths or other thin liquid. Made a start on putting the flange on, but kept getting the angle wrong, so i gave up for the night.
I cant remember off the top of my head, PM me and i'll flick you his number tho.
saaaa-weet, sold. Its still got a roll of your .9 flux core knocking around in it aswell.
I'll give it a go with the mig first, thats tomorrows mission, if i fuck it up horribly i'll come a knockin'.
Washing machine case? heh, thats what alot of my dad's one tonner is made out of. Next time your in repco, have a look at the shelves out the back, they're just over 1mm thick mild steel, hah. The powercoating is a bitch to get off, but one of those has served me well so far. Someone climbed on one and bent it a bit, no good for the store, but good for me, hah!
Thats the outfit that used to be Asco isnt it? Thats who i rent from also, rental is like $8 a month or something, and refills of co2 are also very cheap. Do you know if they do any argon/co2 mixes? Will definatly give them a ring tomorrow.
yup, custom sump is the plan, i dont see it being to tricky, and i know a couple of people i can take it to to tell me how stupid im being and how it SHOULD be done, heh. You want a mig welder? buy my old one! nothing wrong with it, goes well enough, comes with most of a roll of .6 aswell, hah. $300 without regulator if your keen?
Fuel should have put one in his viva, but its the same front rear sump thing. God i hope my idea works, or im up shit creek, and im really not sure its going to.... Ahh well, wont learn any other way!
Went and got some 19mm pipe this morning to play with, then got stuck in. Made pie sections with 15deg angles each side, meaning each one turns 30deg. 3 of these, plus a 15deg angle on the peice coming from the flange gives me 105deg in total, about what i need. Getting the pipe bent would be better, but i dont have a pipe bender, and no one i know has one that can do 19mm pipe, or a tigh enough radius. Oce ive built this bit i'll sit it in some oil and spin the pump up with an electric drill to check it flows. Fingers crossed, as im really making it up as i go. Stuck at the moment till i get the cortina mounts im planning on using, which is later this arvo, as they'll sit the motor closer to the crossmember. Taped some exhaust tube in the place of the rack to check clearance, looking good as this height, but we'll see with the other mounts. I'd really like the motor as low as possible.
Discuss away. Bubblegoose doesnt know this yet, but im for sure going to tax his tigging abilities in the not to distant future. Do you own a bottle, or rent? who from? what are refills worth? Chur.
You rekon? But it turns it into a kadett! (basically). I'd be after a bit more than a fiddy alas. Anytime you wanna mig something up tho let me know. Cant really loan out my new welder, but your more than welcome to shoot over and use it. I only have CO2 tho, not as good as argon mix, but its still better than gasless.
Old welder is up for grabs, swing me a txt if your keen? I'd be after around $350 with a regulator aswell i rekon. I think i paid $500 odd for it on staff when i bought it... Comes with whatever wire is in it aswell, hah! Can also do you a cheap deal on an auto darkening helmet like mine. Yeah, im hoping the cortina mounts will make it sit a bit lower, just getting the sump to clear will be the majour issue.
