Posts posted by dmulally
11 minutes ago, Adoom said:
I've got most of a full sheet of 0.8 cold rolled, but seems more like 0.7 to me. If that's a suitable thickness, let me know and I'll give you some.
Adam
That could be a goer! I wont be seam welding it (ie: blowing holes in 0.8) so it would work. I'll send you a flirty PM
So the new radiator arrived and it looks pretty schmick. It is a bit thinner than I thought it would be but that's not the end of the world. I havent decided if I'm putting a heater in it yet or not so have some Y fittings with individual taps the same size as the original heater lines off the manifold. So I could run it to an auxiliary radiator in the back in summer and a heater in winter. Or just the aux rad. See how I feel. Future winter me will be pissed off if I don't put in a heater box inside.
I was going to just use the bottom fresh air vent box hole thingy for the radiator but half of it will get nothing. So I might punch a couple of 2" holes where the badge used to sit above the bumper bar to get more airflow in. I might sleep on that one. The bonnet is punched full of louvres so that should get the air out. I have to purchase some sheetmetal anyway so might look at some ducting and a mini scoop where the number plate is to help direct airflow into it. Here are some before and during pics. The rad is off to starboard as the fuel filler hose is in the way.- 16
17 minutes ago, JustHarry said:
Is it an iwata w400?
A normal size gun if fine for doing shuts . Narrow the fan up and lower the pressure and lower the product feed . There are knobs for doing that. If your unsure chuck a pic up and I'll point them out
Indeed it is the w400.
I didnt think of lowering the nozzle/pressure. Normally when I do I get runs but I dont really care about that as much as it's all out of sight stuff.
Thanks! -
Has anybody had any joy with small touch up spray guns? I only have a primer gun and a top coat one. But I have to do some small spaces like door jams and some parts and my top coat iwata gun will just blast overspray everywhere.
So after about four attempts I got the gearbox mount bracket sorted. For the welding I couldnt grind smoother I used the tig to flatten out. Sadly I can't box it but I will add some 8mm thick gussets which should be ok but will leave it up to the cert man to let me know. Happy to use the original mounts which is one less drama.
I needed to do some panel beating inside and ended up cutting away the gearbox tunnel which I'll replace when I get some fresh steel.
So the half shafts would bolt right up to the VW cv's if they had the same bolt pattern which is annoying. Maybe a fraction too long so I cant fit an adapter but I will explore it. That would save some farting about with engineering half shafts but not fussed.
Next on the agenda is finish painting the awful green inside and then I might start on the radiator mounting for a break.
- 21
15 hours ago, Snoozin said:
gets high 5s per 100 around town but is a manual.
I was patting myself on the back for getting my 66 C20 from 30l/100 to a consistent 25l/100 with a change of carb.
- 6
Right then. So the reco'd Imp engine suffered a setback. I was on my way to pick it up (Martinborough to Tauranga is a looooong way in a GMC) and 20 mins out got a call it had seized on the test bench.
So thankfully my plan B was already decided upon and brought forward.
I popped out to the LVV cert chap who gave me the green light to use the venerable EA81. It weighs the same as the Imp donk and only the gearbox requires some changes to the bodywork to fit. The EA81 is presently being reconditioned.
The gearbox I have decided upon is a "freeway flyer" VW box. 0.87 4th and 3.8:1 final drive. A massive improvement over the super short Imp box.
Some challenges remain in that the selector is out the top rather than the bottom. So the gear linkage will need to go on top of the tunnel rather than under it. The handbrake and rear seat platform are in the way but I can sort that. Don't really have a choice not to.
I have started on the mount and am up to version 3. I'm trying to use the original Imp mounts and a bracket linking the box to them.
I have a shit load of other things to do but am rushing to get the mount done so I can sort the half shafts. The engineer said he would get back to me on what is acceptable which is fine. I'll get Howat Engineering to sort so I know it will be acceptable.
In other news I dropped off the front seats to be retrimmed. I was going to use original seats but the modernish buckets I have are super comfy. I also had a custom front radiator made for it which I havent taken out of the box yet. It will be fed with the original water pump suplimented with a davies craig ewp Ill put at the other end to help push the water around. I got the springs lowered by Aechers but I think it is a little too low. Might stop being a tight ass and invest in some adjustable coilovers.
It's all happening!
- 27
I use: dannythompson73@hotmail.com
They are pretty flexible about vague instructions (I'm sure it winds them up) but I've had nothing but good dealings. I once bought a motorbike to ride across the states and just rocked up to the warehouse in LA and handed them the keys. Somehow it made it all the way back to NZ safely.
1 minute ago, yoeddynz said:
I'll be interested to see what he says because I'm planning on doing similar between my scooby and imp shafts.
Yeah will pass it on.
If it has be done by a certified machine shop I'll give you a yell and we can perhaps sort something out. Especially if it has to be splined.- 1
On 05/06/2023 at 18:30, HumberSS said:
3/4/5k Toyota?
Lovely little motor (especially with sidedrafts) but would require cutting the bulkhead.
I popped over the LVV cert guys place for a gasbag yesterday and he said if I can avoid as much cutting of the firewall as possible that would be good. I think the only part I'll have to cut is the snout area for the VW box. But that is technically the gearbox tunnel so not a big a deal.
The only question mark he has for me which he'll look into are the half shafts. I was going to cut the Imp and VW ones and weld them together with a collar over it. He said he'll let me know the best way I should do that.- 2
So the subie EA18 fits nicely. Only mods required looks to be the air filter/carb arrangement and the oil filler tube. Thankfully the tube is mild steel so I can shorten it and face the correct direction rather easily.
That inlet manifold needs a bit of a trim with all the extra lumps and bumps sticking out of it as well as I don't need all the vacuum ports and whatnot. Interestingly the original heater pipes on the EA18 are a similar diameter to the Imp front radiator tubing so I can still use that. But the diameter for the original outlets for the radiator are far larger. I'll have a think about it but perhaps having a radiator front and rear could be handy. I could also gut the subie water pump and just use the davies craig one I'll be installing shortly for the Imp engine. See how I go I guess.
Gearbox will be a VW freeway flyer IRS box (3.8/0.82). I've already ordered that as well as an adapter for the subie to VW. I think the one main thing I'll need is a starter but I'll wait until I have the ring gear in hand to check what I have.
15 hours ago, Alfashark said:
Nah, he's throwing a radiator up the front.
Correct.
Installing the front mounted radiator with twin thermo fans and a davies craig water pump which deletes the thermostat. I have to convert to an alternator at the same time however to keep up with the new power demands.- 2
On 13/03/2022 at 14:44, dmulally said:
Right. This engine is already getting on my tits. Open to engine swap ideas.
50-100hp, reliable, and carb. Ideas so far are EA81, Suzuki Carry, 1600 cortina.
I don't care about handling. 99% of my driving is in 100kph zones with long lazy corners.
Google suggests this:
Those instructions are pretty good. As long as it didnt throw an error code or you could pull the little globe you could ignore most of C1.
Dashes are always fiddly to wire anyway. At least yours has great instructions.
Does the digital dash all work?
If it works and you like it just terminate it at the fuse box and try and refresh individual wires to the right places.
If it doesnt you could always change to a custom analog dash. Would be loads out there to choose from and you'd only ever do it once.
The digital dash was prob why it was so hard to find an off the shelf loom.
Thankfully being a small block chev you only need three wires or so to run it.
Oh yeah Id gut that entire loom and start from scratch. With a loom that big I assumed efi/tbi or something.
Take one day to gut it entirely. Then a full weekend running each one out one at a time. I prefer American Auto Wire as the wires are a lot softer than your typical Narva branded ones from Repco so you get them out of the way easier. Then you'd never have to worry about it again.
I cant seem to find a specific one for 1983 so Id get something generic like this.
I was able to cut off the under-bonnet bracing which made it a little floppy but after the stamping is done I can weld in some box tubing to help out. I've coated it in acid to help keep it from rusting in the meantime. Sadly there was a thick layer of bog on it so it will need a bit of mucking around when it comes back to blend it back in.
Dropping it off this weekend so I'll report back when done.
Being an electric motor I assume you could just flip a switch and make it go the other way. With the Thunderstruck control unit that is possible.
I think the bigger issue would be battery physical storage. Unless the Leaf batteries can be pulled apart and repackaged or it could take aftermarket batteries it would be hard to fit.
Blimey that is tiny. Who's is that?
dmulally's pimpin' Imp
in Project Discussion
This is the grill that came with it. Looks like shit to me but would be perfect for a front rad. Lucky I gave it away. Can anybody think of any ideas of what I can put on that is subtle? I'm thinking five 2" holes punched inwards with some mesh behind it.
