Posts posted by Moffmo
All good for my place too mate.
The issue I have with the gear box choices is that I can't go for a normal manual as it's column shift. I've read that there are Toyota ones that bolt straight on without with but wouldn't be able to change gear lol.
How feasible would it actually be to put an auto in. I'm not sure how autos actually work but don't they need a sensor and wiring etc which I won't have?
The campervan is surprisingly light for what it is. Think its about 1.5 ton. But it does take alot to get it going.
It seems I have a decision to make. LPG or 2 barrel carb! Hmmmm.
Ahh sweet. I'm with you now.
Definitely something to look into. Think lpg is half the price of petrol atm..
What's the converter?
Not sure what lpg availability is like in NZ but would probably go straight lpg as it probably saves headache I would imagine.
Cheers guys. Something for me to think about. Will get the bloody thing running first!
Funny you mentioned that because that did pass my head at some point. I wasn't sure how easy it would be to "convert" to lpg but it's a very thirsty engine so a cheaper fuel source would be good.
Is it literally a case of getting an lpg carb and manifold to fit and the tanks and that's it? You're running LPG? Would this also have to be certified?
Holly carb on trademe... Come's with manifold.
http://www.trademe.co.nz/Browse/Listing.aspx?id=1351622230
Worth it?
Cheers fletch. If i see one come up cheap enough I may take a punt.
Oh sweet. Need to look into weber carbs now.
*Googles black magic.
Decided to clean up the footwell areas as some surface rust was coming through so penatroled it and painted it.
Before
After (wrong side but im too lazy to go and take another picture).
Also @Steelies has been hard at work for me, creating a shroud and mounts for the rad for the new fan. He's also going to be modifying the engine lid and engine panel so it all fits. Here's how the fan looks ATM. Getting really excited now.
I have also been offered a 202 black (with manifold) that I can potentially replace the red with. The 12 port head should be gruntier than what I currently have. It has good compression but carbs a bit fucked. I've been told that the varijet carbs are a bag of wank anyway. I'm probably going to fit an electronic dizzy while I'm doing that too.
This leads me to a few questions..
a) Should the black and red swap fairly straightforward or is there more differences than the manifold?
Was talking to @k-trips and @Seedy Al and they advised that you can get adapters for the manifolds so you can fit different carbs - what would people recommend here? Weber?
c) If I were to get an M20 or M21 gearbox (I currently have the 3 speed) - (shorter first gear on the M20 and M21s I think). Should the column shift still be ok baring in mind my current one is only 3 speed - are the movements dictated by the gearbox or the column shift assembly in the van?.. Hope that makes sense.
Nice little meet. Nice to see faces again.
7 hours ago, kicker said:
Aliens
Got Manu involved and he currently has the rad and is building a shroud for it, we are (he is) then going to modify the engine bay abit to accomodate the new fanned rad.
Plans/Dimensions for the Rad/Fan
Thought to myself I am going to rip the carpet off. It's gross. So I did.
Got some surface rust on the drivers footwell. So I'm gonna wire brush it down and penetrol it and then repaint.
I hope to then recarpet with some proper automotive carpet. Does anyone know where I can obtain this without paying through the nose.
Removed carpet (Don't have a before picture..) But I sweeped it up after this picture.
One nice seat
Took the seats out and had a look at the condition of them without the covers. Not too bad so I think I may get these reupholstered.
Anyone got recommendations in the welly area? otherwise may have to do a OS Transit and get them up to Hamilton for Midnight as they seem the dogs bollocks.
Had an awesome week and half in the South Island but obviously we missed alot of it too. Also we had developed some serious overheating issues so had to drive everywhere at 50kph, which also meant pulling over alot.
The rest of the tourist wanker pictures from the rest of the trip
All this time in the van made us realize there was a shitload of issues with the van itself
- Drainage system didn't really drain, it came back out in the shower
- Water pump for the taps etc didn't work
- Couldn't fill the water tank with water.
- Fixed the water pump, so now the water heater started leaking
- The gas wasn't really plumbed in correctly
Needless to say, alot of the trip was spent trying to fix things that I could
- I installed a new water pump
- Relayed all the piping for water tank to the pump.
- Installed a vent pipe for the greywater tank
- Installed a vent pipe for the freshwater tank
- Fabricated (I bought a lunch box) a drip tray for the water heater.
So anyways. We got home and the first thing i did was remove the rad. Gave it to seedy and he had it rodded. It was 80% blocked, I also replaced the waterpump and put it all back together, but it's still overheating.
- 5
Discussion -
I picked this campervan up late 2016. I took a bold risk by sending an OS member to go and see it for me and then agreeing to buy it unseen.
So we flew to CHCH and got the bus to Timaru. Picked it up, so off we went.
Drove it 30 mins down the road engine cut out. Good start...
One overnight stay later, I check the dipstick in the morning and the oil level was super high. The guy came with his tools, fucked around doing random shit as if he didn't know what he was doing and it wouldn't start. Told him to just drain the oil for me and see how it goes. It started. So off we went.
Get to petrol station, fill up, won't start. It was obvious that the battery was flat as no lights etc were coming on. Asked the petrol station lady if I could use my leads on her car and she agreed. So off we went.
Luckily I'd agreed to collect an axle/diff for Kicker from Karl. So I rang him and said can I meet you at a petrol station and can you bring your jump leads? He agreed. Met him and then he jump started me.. So off we went.
So for the rest of the drive back we agreed to fill up with the engine running as it was OK when it was running.
Get to Picton, So close to the finish line! - Engine cuts out as soon as I pull up.. FARRKKKK SAKE. Anyway had a mobile mechanic guy come out and he gave me a new battery and put it on. So off we went.
Drive it off the ferry, all good. Get to the hill just next to where I live and it was pretty obvious that the clutch was now starting to slip.
What the hell have I got into I thought to myself.
The van very shortly after we picked it up.
Luckily I am surrounded by GC's so I got Seedy involved and he basically replaced everything that was old and shit on the engine (including new alternator and ALL the wiring for it!). He also fitted a revometer cos he was all like "Dude you're a deaf twat and you're revving it soooooo much so I'ma fit you a revometer in so you can see what you're doing". Like seriously, that's so awesome how he made the van more accessible for deaf people.
There was still some hesitation on the engine wanting to rev, but it ran and started reliably so road trip around the south island for 3 weeks.. So off we went.
The beginning of the trip..
One of Jokers Work of art
Waterfalls
Had a pretty fucking couple of days then headed towards CHCH. When bomf, no power at all. Fuck.
Called AA. Guy came, Timing gears have stripped.
This is where OS really shined. Never met any of these people before apart from Karl and you all made sure we got back to being on the road.
Felixx came and towed us to a campsite near him/karl where we lived for the next 4 nights until the shops were open again for us to pick up parts. In that time, luckily ThreeOnThree was in the area and had organised with Karl a South Island meet where they would be destroying a triumph, but they also now focused their efforts on helping me get the timing cover, gears, and harmonic balancers off. This was harder than it should have been but everyone came through. So thank you all.
Triumph being dismantled.
Engine and rad
Felixx clearing the rad out
The pony old electric fan
The engine
OS south island krew.
When good head comes together.
Shitty Fibre gear.
Went to rare spares, bent over and pulled my trousers down and said please rape me, I want the timing gears for an holden 202 in alloy. They preceded to truely butt fuck me but at least I had the timing gears at last. Got a mobile mechanic to help me finish off the job and we were back up and running.. So off we went.
5 hours ago, igor said:
I can't see how a Honda Odyssey can be considered economical. A guy at Church had one for a while and reckoned it hogged the gas the same as his coon or even more.
A chick at work has a Vitz RS and loves it. Would not recommend the base model Vitz though. They are grossly under powered. Also +1 for Jazz. Late FIL had one and it went bloody hard until the old sheila parked it in a tree.
I suppose it depends on what is considered economical.. I would class anything over 30mpg for a 15+ year old car as good. But I went to rotorua from welly and back (as well as driving around rotorua for 3 days) on 2 and a bit tanks ($70 - $80 fill up) which impressed me to say its a 3.0l v6 with 210hp!
Depends on the budget and what kind of cars you can get for that I suppose. If you're going to spend more money on something newer then yes there are more eco cars, but he's asked for a shitbox ha.
I have to agree with the motorbike route. This is what I use for my commute and it's pretty awesome filling up 2 times a month and it costing $16. Shame the price of rego cancels it out, however it's still worth it for me as its cheaper and more convenient than a bus and I don't have to worry about finding and paying for parking.
Got a Honda oddessey 1998 (ra1). It's in awesome condition and seems quite economical to me. I'm wanting 1500 for it. The only issue I've had with it is that the boot seems to get damp.
Its a v6 so it goes nicely.
Farkkk that looks well nice.
My favourite thing about the van van is that ridulous back tyre :
Don't be like that. GN250s are awesome!!*
*Once you replace
The stator
The voltage regulator
Rear sprocket
Front sprocket
Chain
Seat
Throttle cable
Revometer cable
Exhuast
Carb manifold
What compressor did you have before?
I'm in Rotorua next week. DAMN IT.
I'm no longer dragon boating after today, so hopefully can make the rest!
Just now, cletus said:
Technically it should be re certed
However if it's already got a cert for 'holden diff' I would say most people would assume it was changed to 5x114 when it was certed and you would get away with it
I had that exact thought recently, becuase the cert does say " with holden 101 diff conversion" in it.
3 hours ago, JoKer said:
is there a build thread for the Van? ttiuwop!
Nah, cos I didn't do it... Even if I did have one, Seedy and his mum would have to write it as he's done alot of the work lol.
Mofs Toyota Hiace/Holden
in Project Discussion
Wow. Amazing write up thanks! The budget part really appeals to me.
I will keep an eye out for an 32/36 as it sounds this would be less work. But if I see the 34 adm for a good price then I know the option is there too.
Thanks for taking the time to write that up!
