gettinroundtuit
Everything posted by gettinroundtuit
gettinroundtuits 73 avenger
gettinroundtuit replied to gettinroundtuit's topic in Projects and Build Ups
gettinroundtuits 73 avenger discussion
gettinroundtuit replied to gettinroundtuit's topic in Project Discussion
STROKER CRANK IS IN THE BLOCK!!!!!!!!! -
gettinroundtuit replied to TimShadboltfan27's topic in South Island Region
Going out tomorrow for a look, on the way out to do some fishing- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
????????????? Nothing i wanted anyway ! Going back for another look so i'll look for any cars starting with M for you.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Last time i was in there @ a year ago it was mostly jap stuff with 1 or 2 aussie stuff & a bunch of old tractors....... & a hunter, no avenger shit- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Strip it to a bare shell, fix what needs doing & toss a coat of paint on it. When shopping yesterday - CA18 det rods!!!!! Off to Probuild shortly check out crank progress & drop these off. -
Now it is, cranks just been welded to suit standard avenger thrust bearing location, way easier doing that than engineering block to suit 2y crank. Next, shave center main journal on block to suit the crank, grind mains to std avenger bearings then........... dig up some rods from somewhere. CA18 det anyone? Avengers dying....... so now escorts been evicted from shed & with needing to swap in another temporary motor, loaded up the wagon with 5 speed box & diff to get them sorted & get them in at the same time ( if they're back in time) patient..... donor...... for a worthy cause. Probably end up with double the power! -
No, this is a temporary fix, has bad rattles under load now, Edendale hill's become a challenge to get up without LOUD protests. New crank getting work done now on thrust bearing faces then block gets hair cut on center main journal so crank drops in.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Probably go for a nosey as usual, chryslers feature this year, can't see avenger getting there- it's getting a heart transplant. No more smoke trails & more speed!!!!!!! Should please those of you stuck following & getting asphyxiated on previous runs! Escort's been ejected from garage so i'll bring that- has an ounce or 2 more respectability.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
I'm working all weekend- rush job to get done before christmas- escorts still in bits & avengers not likely to be allowed anywhere near any race track given its current habit of marking its territory .- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Sounds like a good excuse to combine that with a bit of fishing. May need to swap avenger for a better tow car though- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
I'll pack a spare oil pack, full jerry can & 2 spare wheels- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
I'll probably take a cruise out there for a look- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
& i'll probably get done for visually polluting the environment, not to mention the Earnslaw rivalling smokescreen the old slug can lay down
Hi, am hopping over the ditch for Bathurst & flying outof Queenstown on 5th Oct back on 10th, anyone want to have a p.o.s avenger devaluing their street for a few days? Looking at a plan B in case plan A falls over
Might have to miss this one, have a prior engagement that day- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
I believe so- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
I'll be back from the west island before then. Currently 'trying' to save for a trip to go climb a certain hill with a view.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Dam, currently too broke to go anywhere & dont have suitable wheels anyway. Highland not likely to let the avenger anywhere near the track considering the smokescreen it lays now & escort would have to be towed to get any real speed out of it- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Been shopping on trademe, road trip to Port Charmers to pick it up today. Long awaited 2y crank trouble is its still wrapped up inside an engine. Now to strip it tomorrow night & get crank off to probuild -
Limiting factor was not packing the earmuffs. Revs its got, what it lacks is sufficient pony power to push it there......- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
That the reason you wouldn't let me get close enough to pass you on the trip home?- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
That. Aint. Happening!!!!!! Already shot that idea down. Only rotor in avenger will be the 1 in the distributor- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Why a sadface, considering the abuse that motors suffered i'm not that worried. that was my 1st thought too, makes it go away. gunna dig out a gauge & put that on it- could be just a dodgy sender- otherwise pull motor & have a look. Anyone want a boat anchor?- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
