Posts posted by AALAWS
Hey folks,
So I have investigated the option of fitting Rack and Pinion steering to my KE25 Corolla.
With out delving uber deep into the science, I have ascertained that a AW11 MR2 rack, with KE70 brackets to mount it to the cross member, a KP starlet steering shaft and uni, and possibly some starlet outer tie rod ends.....it should work.
I'm at the point where I need to make the decision in my build to do it, or lose it and keep the standard recirculating ball set up......
Is it worth it to convert it? what will the benefits be for a road car (with 20v Blacktop 4age)......is it worth doing it? Yeah nah? -
23 minutes ago, cletus said:
I'm doing a car for someone at the moment which has a set of wheels with bigger lips done by pine, the only issue was one side of the rim doesn't have a bead hump so he has to run tubes.
The side that doesn't have a hump, is an original one though, not on the barrel supplied by them.
Might just be an arse covering exercise, like heaps of other parts manufacturers that say something is "for race use only"
Thanks for the advice mate, I can proceed with the plans
Hey Guys - sorry for the Noob question but I've read and seen a lot about people widening wheels.
I'd like to buy an old set of SSR MESH to sit on my ke25 build while its at the panel shop, and have lined up a set that need reconditioned...and I may want to widen them when they get reconditioned depending on how the car sits after the panel work etc. I saw on PINE engineering that their barrels etc are only for race use........what's the rule around this?
last year an old barry drove his lawnmower into a power transformer and shorted out the street......right when I was doing a computer backup.
I replaced my spa pool control board and the munted portable hard drive and wrote off the loss. A bit later I had to do a system restore from a backup to clean it up a bit (after watching a dodgy All Blacks live stream), but I had lost my recent ones with crashed hard drive so used an older one, thought nothing of it and moved on.........until I went to re-assemble my freshly blasted/painted/plated TE27 pedal box etc on the weekend.All my "dismantling" pics were lost in the process, my caliper ones were in there too......Bugger!!
So I've put it all together the best I can remember. There may be a few washer or spacers out of order but meh we'll get there.
I need to replace a couple of rubber stoppers/grommets that sit in the pedal and cushion them when inactive......all 4 of mine were worn and split, and I need the boot that sits over where the accelerator bracket meets the cable through the firewall.....anyone know where I can get something similar from?
Yarns here:
- 6
1 hour ago, avengertiger said:
a mate of mine collected this in invercargill and drove it back to nelson it had a record 10 aa callouts to get home and drank oil like an alcoholic on a hot day.But even still he said its a lovely car to drive 3.3 4 on the floor.
10 callouts!!?? maybe after the 3rd or 4th they'd have maybe figured a tow truck was in order?
15 hours ago, scooters said:
bitchin... how many hours did that take ?
2 weeks solid ha ha 90 - 100.
He needs a few mods for better mobility, but thinking of putting him up on Trademe.....- 1
12 minutes ago, Geophy said:
Is it possible when dealing with window companies to ask for a certain brand of window? Which are good brands to look out for?
You can request genuine - it's down to your insurance company if they agree to pay for it though.
I never had anyone ask me for a specific brand apart from OEM - you can always try I guess, though saying that, sometimes there is only 1 or 2 options available and you have to take what you can.
As for other brands, I have found FY (korea - they supply direct to Audi and VW) and Australian Autoglass are the better of the aftermarket brands I have used. XYG (China) is the most common and is ok in general but rarely the odd batch or car type can have issues. Avoid Moran if you can - they are always a little thinner and sometimes undersized (mm) which can leave gaps between moulding and aperture if not anticipated and countered with a wider trim or similar fix.- 1
sweet as, should be a 5 min fix. The pit fill is a softer resin than the repair resin and this is a common thing
On 11/10/2017 at 20:34, Nominal said:
Going to have a go at installing a windscreen in the wagon on Sunday.
Q for the pro's @AALAWS @RB30VB
I can only get a seal in a length, not molded. Should the ends be glued with anything or just a bit of windscreen sealer.
Where's the best place for the join? I was going to go for off-centre at the top (as there is a joining piece in the centre of the trim so it's not as well locked in by the (wide) SS trim there.
For the back glass I've had some new pieces cut from laminated glass. This is a bit thicker than the toughened glass that was there. The seals are new, do you think they'll work out OK?
Yup as said above - Superglue on the joins is the go......you can get the join looking seamless with some accurate guts and glueing.
As long as the thicker glass still sits nicely in the rubber without it spreading the channel you should be all good.
yo - if it's just the top layer of resin - the 'pit fill' - you can have that applied again and smoothed over.
It'll tidy it up a little, but it just depends on how dirty the pit has become.If it's the main chip opening up again the only way to fix it is to replace it.
BTW - not all the aftermarket screens are crap - it depends on which brand you get.
Long time no post.......2 business's and 2 small kids and buying the house will do that to your time and $$.....
I've spent a bit of time working on my other Toyota project....to fund my other Toyota project.....
I am waiting for space to clear up at the Panel shop to get the body work underway. In the mean time I've managed to track down a few panel cuts and some NOS to boot!
There's been a few false leads of random shells around from as far as Horopito to the Phillipines.......Horopito turned out to be a ke35 and the Phillipines never eventuated.
I am still excitedly waiting to hear on another potential shell. I was picking up some camera's for a video job and the guy had a 1200 coupe in the garage......as I usually do now, I asked him if he had a spare ke25 shell and turns out he does.......it is yet to materialise but I will keep chasing this up!Just need a drivers side now! Also have a complete rear panel (Taillight surrounds/lower valance etc) currently in the next ML Racing container form Japan.
NOS indicator lenses - Much shiny goodness!
- 15
Cheers Guys!
Can't wait to get them here in the flesh.......they look soooo good......just need to win lotto to finish the shell!! -
KABLAM!!!!!!
- 59
Thanks to the guys with the offers for help!
I gave the calipers another clear coat and they are finally coming right - will give them a bake soon too.
When I bought the Dupli Color paint, I didn't want silver, but a darker grey, so I got a high heat paint with the dark grey top, not caliper paint. But they still came out more silver like........went to get another can for the rears and discovered they have recently changed the colour of the lid to a light grey for the same paint because they knew it was a misrepresentation - thanks dicks!Anyway.....teaser pic of very cool things to come........Recaro seat custom skinned ala TE27
- 7
49 minutes ago, jesselc said:
Ha! Was just about to say the same about the poolude wonder if it's the INX or standard pop up headlight one.
Damn weirdo INX non pop up fronts!!
45 minutes ago, kyteler said:I don't see any R30s there. There's definitely an R31 though but it's not a GTS-R or X so I doubt Ed would give a fuuuuuuuuuuuuuuuck about it. I know I don't.
who said R30??
Lada for Euron8, a few mitsi's for .........well quite a few guys, a few Shuttles for Chris R, R31 and Lasers for Ed, looks like an orange Chevette for Yoeddynz, theres a 1st gen blue civic hatch, ke70 wag for every Toyota fanboy ever, a bunch of commies and bluebirds....and what looks like a silver Cefiro?
Personally, I'd like one of the last of the pop up headlight preludes with facelift clear taillights, or the oldlegacy wagon - if GT.......my shameful foams- 5
so I Painted the callipers almost a week ago with dupli colour high heat colour, and clear, and they're still tacky.
The clear can says to bake in an oven at 200deg, but I thought a few days in the sun atleast should be ok.....but it's still tacky.......any ideas? -
wow - October was my last post......
all my time has gone on my family and new business - and so has any money i've made from it too (who would have thought).I've painted up my front callipers and hubs and will put them back together soon - I've got to find things I can do with no spare $$ or major time.
Bit of a plea for help here.......
I'm in desperate need of an experienced friend!!!, a jack of all trades - a mentor to take me under his wing!!
I look at my shell and all there is to do and maybe redo (and the fact I'm a total first timer and my experience is limited to, reading oldschool posts, internet research and yarns with people)....and I am feeling a bit overwhelmed, well a lot overwhelmed! I try to think I have a handle on the next step etc but man I could go on about all the questions and doubts I have about things.....My old man had a stroke a few years back and he's pretty closed off to getting involved because it makes him feel pretty shit that he can't do anything these days.
Is there any folk out there in the Waikato that could lend a hand? even if it's a few yarns to help me get my head around it all and put a few doubts to ease??I have beer in the fridge and an espresso machine.......whatever takes your fancy!!
My mate had one back in the day.......was a bit of a barge.
It was affectionately known as "The Brick".- 1
Liking the resto goal: "Thing is I want this to stand out from the rest of the RFB crowd and dis-associate as much as I can"
My old lady had 2 of these when they first came on the scene and when i was learning to drive - super nice cars.
I was a happy boy when I was allowed it for the night!- 1
Recirculating Ball vs Rack and Pinion
in Tech Talk
Last time I drove one was about 17 yrs ago so I can't say......
I assume a rack would be better than the standard set up, but just not sure if the gains will be worth the effort you know?
