Posts posted by Kimjon
I removed the external threaded conduit as well. The internet is full of over complicated solutions for blocking the hole it leaves...this is what I did:
Installed:
I did shave about 3mm of the bolts head, just to aid clearance as it was a tight space. If I'd gone for a slightly shorter bolt that would have solved this issue too...but I have a lathe...so quicker for me to take it off that end.
Working on the brakes. It has a huge drum in the rear and a disc up front. May as well make use of what's there...so here goes:
This random selection of bits I found/made should almost do it.
Should be becoming clearer now
So a cable will go around the groove in the "roller" on the bolt. The other bolt has a 3mm hole in it and the cable will double through it and once tightened should lock the cable.
More pics later.
I've been riding my newly made goped around for about a week now...goes awesome, not too loud, quite fast, reliable... yada yada yada...
So then inspired by getting back on this goped, I dug out my other two that were buried behind a mountain of shit in my shed... no easy task.
Holly fuck they're fast! It's been so long since I've ridden them I truly forgot just how insane the power band is, I nearly flipped it first go!
The red one (pictured in the middle) is geared lower and has a brutal transition between slow and hold the fuck on!
The blue one pulls like a school boy from slow right up to warp speed, but is far smoother to ride. In a straight line the blue one is fastest.
Cool, looks fun
@Muncie what size motor were the carbs off?
Then I kind of got in the zone and forgot to take pictures...oppps?
But I made:
-An adapter for the air filter
-Cut up an RC car expansion chamber and made it fit this application.
-And machined up some fiddly little stuff to adapt the carburetor to take a cable, as the original was driven by a RC servo.
I fitted a deck and other bits left over from past goped projects. Replaced all the old fuel lines with new.
Pulled the starter...brommm brommmm...yeah buddy, success!!!!
- 7
7 hours ago, a.craw4d said:
@Kimjon Have you tried this on any of your chinese 49cc 2smokes?
Opened up the intake with a drill and scraper.
Did it to the go kart yesterday but can't test it as I've run out of 2t fuel. Was in a hurry and poured the rest into the tank without the fuel line attached.
Bugger.
I haven't specifically tried that one, be interested to hear how it works out for you?
On a goped, I once drilled out the main bore to the next size up right through the carb, manifold and cylinder head. It was quiet successful, but that style of carburetor has high and low adjustments for fuel mix ratios...so they are easy to tune.
7 hours ago, Raizer said:
Dude! You've done such a great job on this. So impressed that you can take it from trash to factory fresh without giving up. I can see this isn't the type of project where you give your licence plate number to the disinterested 17 year old behind the counter at Repco and expect them to hand you some parts...
64 valiants kombi go-kart
in Other Projects
As long as it has cup holders somewhere on the inside, i don't think you can go wrong
