Posts posted by Kimjon
21 minutes ago, Muncie said:
Did you find out what killed it after the post mortem?
Not 100% sure. But suspect a fin on the flywheel broke off, then jammed up the flywheel inside the cover...but I'll never really know for sure?
It stopped in a hurry which flogged out the keyways on the crank. However years ago, to advance timing on a goped, I once removed the key entirely and advanced the flywheel a calculated amount, then simply did it up tight! That motor still goes great to this day...no key used at all. The taper is enough to hold it there.
So on this one, I hammered the crankshafts two flogged out keyways back into "rough enough" shape, filed off the excess, put the keys back in and did it up tighter than before...seams to be working fine
I'm sure this shit goes all the time...just most mechanics wouldn't tell ya?
As Chumbawamba once said:
"I get knocked down, but I get up again
You are never gonna keep me down
You are never gonna keep me down"And V2.0 rises from the ashes like a Phoenix!
The epoxy on the manifold cracked...but at least I know it all works. So I ordered a proper manifold (like I did months ago) and fingers crossed they send me the right one this time?
Ok... small set back happened shortly after
It decided to blow up! I was resigned to the fact that lots of small bits of metal all over the floor usually spells catastrophic failure. But I think the short block is okay.
List of fucked up shit includes:
-FlywheelI
-Ignition
-Fan cover
-Pull start
-Clutch
-Intake manifold
-Possibly the crankshaft (though I think I "fixed it" with a hammer and file?).
The cases and cylinder head are okay. I think the clutch or flywheel contacted something or came loose...then shit spinning at about 16000rpm wanted to stop spinning!!!
Luckily I have parts to fix, so V2.0 coming soon
38 minutes ago, Muncie said:
Fuck yes! Sounds half way between a swarm of wasps with laser beams on their heads and a huge chainsaw. Don't spare the safety gear on your first ride picking it'll be an absolute handful to ride.
Haha...
Going to swap carbs over to a slightly bigger walbro, as I suspect it may be running lean on the LSN.
The bigger walbro has a dedicated needle jet in a more accessible location to adjust/tune. So that'll be this afternoons mission
Big development...it's alive!!!
I don't have any cables controls hooked up at present...so tuning will come later...but fuck yeah!
Sounds Harleytastic!
I got hold of some thermally conductive grease, used for heat sinks in electronics.
Took the head off, flipped the copper gasket rings around...put a thin layer of the grease between each of the outer head mating surfaces (I smoothed it out evenly) and put it all back together again.The tooling grooves between surfaces don't transfer heat very well.
Think that should be it for now. Still waiting on my handlebars...but everything else is done.
Nice work, can't believe I had never seen this thread before.
I've been working on something similar off and on (well...mostly off) for the past 3 or 4 years too. It occurred to me the other day just how close to finishing, but meh...why rush?
Great seeing another hard tail is out there, keep up the good work.
Cool, cheers for the tips @Muncie
I got this tensioner mechanism sorted! It's all working as it should, but for now I just have a bit of rubber in place of the chain roller.
I'll buy a chain roller for a pit bike, I've used these before and it worked great on the other applications.
I'll tidy it up a bit and then call a day.
I took onboard some advice and shifted the chain roller further away from the pinion gear. It now contacts the chain close to the middle of the span between the pinion and the driven gear.
Its just sitting on there for a quick photo. But you get the idea. I'll finish it off, and sandblast it to reduce drawing too much attention to this part.I added a pin on the end of the handle you push to adjust initial tension. This was added to catch the chain. So now if the chain breaks, it's gotta get past the expansion chamber, then the handle pin and the pivot pin on this tensioner. I feel a lot better with all this redundancy.
Jealous, like seriously fucking green with envy!
I was worried about what could happen if the chain was to break. So I decided to fit a guard.
The guard may as well perform a dual function, so I came up with this tensioner system, that will put pressure on the chain to eliminate any slack.
I need to get a bearing/roller to complete. But those are easily available.
Now the chain should run sweet, but if it does break it hopefully gets deflected by this and doesn't whip me!
24 minutes ago, Muncie said:
I think I like yours better....... liking the alloy deck do they get slippery?
Not too bad.
I made my own (deck) about 20 years ago for this goped sport pictured below:
The deck has never caused an issue. Although in the wet may be different?
I still have that scooter... and it still hauls arse, with a power band like a sledge hammer!
It was the first motor I ever fully built myself. Its a hybrid with Zenoah G23LH cases and crank, with a Zenoah G290RC head and piston. That's 22.5cc and 29cc with the resulting hybrid ending up at 25.8cc. I gave it a very mild port job, advanced the timing, raised compression, added a bigger carb, made a velocity stack, lightened the fywheel and added an expansion chamber.
When I built it I really didn't know what I was doing, but somehow fluked a pretty good resulting product.
180cc @ 5.5hp. It will have no trouble spinning the wheels with 4-stroke low end torque.
I'm going to lose that gas tank as it's not my style. I tend to add my own little touches to these things.
The front end was fucked. Luckily I had a spear one leftover from the "Mike trike" project.
Between the two front ends I can salvage something workable.
I'm also experimenting with this seat idea. I'm not in love with it...but figure I've come this far, may as well see it through. Perhaps a few dimple die holes to make it look the part?
Then I turned up a sexy retaining plug for the stem, as it was missing one.
Kimjon's not as cool or epic as Muncie's off-road goped Bigfoot scooter thingy
in Two Wheels
I'm putting way to much time into this thing. But waiting has never been a strong attribute of mine...
