Everything posted by Kimjon
Not terrible, looking pretty good now. I shifted the lefthand side of the front shield forward fuckloads (almost 100mm), righthand side about 40% of fuckloads. Its within the ballpark now, I'll flatten out my sins from the beating it took (another day) with a planishing hammer, but overall its surprising good now given how much of a hit it had taken in the past. Pretty happy with this so far. Be a fucking cool scooter when done.
Shit photo, but I've started collecting parts for this round tail frame circa 1959-62 vintage. I put a PX disc brake front fork into it, which will also come with a 10" wheel conversion. Its a bit of a resto-mod build. Frame is 100% rust free, but has a bit of front-end damage. Nothing a hammer can't fix. It was stored hanging from roof rafters for the past 30 years. So I got lucky finding one thats rust free. Pretty much have most parts to slap this together. But no hurry to do so.
For oil priming, assuming you have oil in it, ready to go. Take plugs out and ground them (or disconnect coils). Undo the lower of the large flat head screws on the oil pump. Put a magnet in the hole and pull the ball bearing (check valve) out. Let oil bypass into the hole you'll see, that the ball bearing would be blocking. You can put you finger over the top hole and let it flow for a few seconds. I even cranked mine. Put the check valve back together. Crank motor over on starter until oil light goes out. Do this in 5 second bursts. But mine pretty much went out straight away. Good to go...
Hiding the wiring inside these aluminum channels I roll formed for the job. Once again, ridiculous amount of time and effort, but I think its worthwhile as it'll look pretty clean because of it. The holes are all multipurpose, they hold things above, like struts, stop light etc...and the opposite side holds my aluminum channels for the wiring to hide in. Looks super clean.
View of plate holder/axle slide mounted on the bike. I'll paint the braket black, so it doesn't stand out.
Number plate bracket, and axle block multi function part. Without reliving it too much, a stupid amount of work went into this, probably 12 hours or more. The block, not very visible on the side has a lot of engineering time put into it. The bits you can see only took an hour or so. Its a really complicated solution to a straightforward problem.
Rear mini Bates stoplight fitted. Matches the iconic Bates headlight, so as far as stoplights go its not the worst I've ever seen. Once again, I read the rules around placement and it needs to be seen from certain angles and also has to comply with certain standards (E marked, or SAE, DOT etc). My indicators, headlight, and taillight are all compliant with the standards, so hopefully thats one less hassle to deal with.
Made fender struts today. I'll either powder coat or get them chromed eventually. My mind had been going in circles with turn signals, as whatever I try...its ugly. Unfortunately the rules for these require them to go in the worst place visually to be compliant. I'll run these for now, come back to it another day (or not?) If I still hate them in the future.
Pretty stoked with this belt roller, solves a problem and doesn't look out of place. Ive designed it to only be in contact when the slack side whips around, normally if you chop the throttle harshly. The rest of the time it won't touch the roller.
- 299 replies
- 18
More rides, more hero shots...no dramas...taking it easy - but its got enough ponies to be fun to ride.
- 299 replies
- 17
Fuck the fender...I can ride it without one. First test ride went smoothly. Nothing weird happened, and the ride quality was better than expected, especially taking into account that I've got 36psi in both tyres to set my fender gaps off.
- 299 replies
- 16
Setting up rear fender. Im redoing all my original ones, as they were set up on a 16" rear rim, but im now running a custom 17" rear rim (harley softail hub, laced into a modern 17" rim) to add extra ground clearance.
Need brake fluid, then could ride. But ideally I'd like to mount the rear fender before riding...but we'll see what happens
- 299 replies
- 26
Oil lines plumbed up, exhaust mounted, basically its ready to start. I might hold off until I've run the rear brake lines and bled them etc...but in theory I could put fluids in and hit start now. Still a few niggling issues to resolve like fender struts and rear wiring to be fully ready. But fuck yeah!!
- 299 replies
Waiting on a few things to come back from paint, like oil tank and exhaust brackets...then I should be able to try starting it up for the first time.
Starter jackshaft arrived. This isn't the correct one for my parts, however I ordered it on the off chance I could make it work. Long story short, I took the original jackshaft and this one, swapped a few parts around, did some witchcraft in the lathe and fingers crossed I've made a working starter motor with cushioned engagement pinion. Time will tell...
