Posts posted by pbaines
Olds Cool Autos could probably do you springs, fire em a message and see how you go
So it begins.
I bought this here new old welder off tardme for $350 shipped and went and got some gas for it. Turns out it has a 'spot' function too which is cool, makes the welds a lot more consistent, not that it makes my work look any better... been a few years since I have been working with the gun.
I began by making all of my cuts that I needed and sprayed in some rust kill sealer on the underside where I could
Water had gone into the roof and then down the A pillar so had completely rotted this section away
Tacked them in
I don't think this would have been nice on a rainy day....
Welded them in!
The corner section of the roof was challenging as it was a 3 skin section but I think it's turned out pretty well in the end, overall very happy with the look of it all
That's it for the body cuts, may have a few holes I need to fill but other than that, it's looking pretty good. Minimal warping on the new areas, not the biggest worry as I need to bog skim the entire roof anyways....
Will head into town next week and purchase the filler primer and boggy and will make start on the rest. I need to do the doors at some point too, theres minor minor rust holes in those so should all be okDiscussion:
https://oldschool.co.nz/index.php?/topic/56136-pbaines-1977-toyota-corolla-ke30/
Been a while, but uber keen to crack into this over christmas break. Have taken 3 weeks off so I hope that I can get a shit load of work done to her!
A weekend ago I rustcoverted the engine bay after taking it 99% back to baremetal
It did go to a proper black even though it's quite blue in this photo
Then since I had left it bare for so long and the car was a mess, i took it outside and blew all the crap out of it and vacuumed the floor. There is 0% rust on the floor at all so skeptical if I should even remove the sound deadening stuff.... but none the less I cracked on. I got the grinder out with the flappy scratchy thing to take back the rust but to be safe at the end I did the old vinegar-water rust killer trick.
Mixing Water:Vinegar @ 4:1 ratio I scotch brite'd the whole car where it was bare metal and let it sit for a bit, came back to this beautiful orangeThen It looked like this, so I went over it once more till i didn't see an orange speckle anywhere using 100% water and drying off with handee-towels.
With two cans of epoxy sealer/primer at the ready and letting the car sit in the 29degree sun for 5 minutes just to give it a bit of warmth I rolled her back in the shed, tacked the car off and then layered the goods on (while do one more two can coat and then use my gun to lay on the primer)
Over the weekend, the famous Grant came down to install the seat covers that he had made for me. and wow, they look great!
I installed everything just so that I made sure I had all of the clips for the door cards in place from the get go, and that I also wouldn't lose any of the bolts for the seats etc.Even doggo thought they were nice..
excuse average photos. the DSLR wasn't available today.
Grant also did the door cards
Will be closing and locking the doors on the KE25 until I get the AE86 going again. Really pushing to get it finished before end of March next year for Toyota Fest....
Discussion:
https://oldschool.co.nz/index.php?/topic/52401-pbaines-1971-toyota-corolla-ke25/- 9
And then it was time to drop her in!
Installed the 230mm clutch and flywheel assembly. Had to grind out the T50 bell housing so that everything could fit in nicely. Took half a day to do it.... enough meat to hold it all together I hope!!
Extended pilot bearing that came with the SQ-Engineering conversion kit
[/url]
Super easy to lock up the flywheel ready for torque
The goods go on.
Pilot bearing has plenty of insertion
Starting to look like a car again.
Discussion
https://oldschool.co.nz/index.php?/topic/49929-pbaines-1985-ae86-corolla-levin/
Started on my cuts as I have sourced all of the replacement sections that I am needing
Found a patch on the car, shame it's rusted through. the whole thing will come out
After many hours of using paint stripped which did absolutely next to nothing, i went with a wire wheel on a grinder. Will continue more next weekend after I drop the subframe out etc.
Discussion
https://oldschool.co.nz/index.php?/topic/56136-pbaines-1977-toyota-corolla-ke30/#comment-1844319
Painted the cam covers a nice semi-gloss black
I have a W58 on the way, adapter kit from SQEngineering and also trying to sort out a clutch setup too.
As it is more a daily driver I would like a Puk clutch type but with springs otherwise will be super bad in town conditions.- 3
On 23/07/2017 at 16:04, Snoozin said:
Set of 193b's sitting in my wardrobe doing nothing at all that would surely be lush.
What type?
6 minutes ago, Bistro said:
ah right on, then I have no wheels for you then haha. the world is your oyster when it comes to rims in 4x114.3!!
I think that's what makes wheel choice even harder
1 minute ago, Bistro said:
Are you still on the look out for some MkIIs? is this still 4x110? I might have some 13x7 and 13x7.5s that need some work
Ps, loving the progress - great build.
I'll be going to 4x114.3 as I'll have the AE86 rear diff setup and also AE86 front suspension also.
I'm still umming and arrring about wheel Choice haha. So many to choose from, finding some that are the right fit is hard
11 hours ago, Seedy Al said:
Fuck this looks rad on street fins.
I like how you just throw money at engines all over the show lol. It's good commitment.
I'm hoping that once they're both going I will think to myself it was worth it...
But yeah. Street fins look good, especially the CR ones on the rear. The fronts are ST's which are the most common
So one day I decided that the power wasn't enough and I needed MOAR so have decided to build a turbo motor which will be around 250kw expected BHP using MRP bolt on pieces.
ps - I am shit with making up my mind...... motor goes in, motor comes out. rinse and repeatMotor specs are: Stock bottom late GZE setup with ACL and ARP internals
Mildly ported head and oversized valves, stock cams for now but will go with some Kelford to suit Turbo engineARP goodness
Pistons go in
Covering her up
Late model GZE pistons which are 9.0:1 and are factory forged. that is lubricant making them look dented, they aren't...
More ARP's
I will probably end up going with kelford cams, but I just wanted to get everything setup for the time being
I will also paint the rocker covers...
One day!!
Discussion:
- 9
Today, I installed a clutch, and dropped the old girl in.
Finally! I also installed the missing headlight bracket as it is different for the corolla vs trueno. It's taking shape now!
Next will be getting the diff shortened.
For the yarns
Top 4A-GE
Bottom 2T
Ahh. So i made a bit of a large cock up.
The cams were far too big for the original pistons, the valve reliefs were to small and when I was dialing in the cams the lobe was hitting the piston by a long shot. Instead of crying about it, I ordered some 82mm (2mm oversized) 12.5:1 compression pistons from Barry at MRP. Took my spare 7-rib block in to the machinists and got that block bored, cleaned and decked also. All is not lost with the other block, I will be using that in my AE86.I put some new frost plugs in the new block and gave it a blase of semi-gloss paint
Whipped the head off of the old block
Removed everything as it was instead of dismantling it (take pulley -> timing sprocket -> oil pump off, all to put it back on again)
Went over to the NEW block, gapped the rings and dumped the goods in. Much better
I set about to degree the cams, this time. No fowling on anything!
Reconned alternator which is an 80A oneIt's nice to work on an engine and still have clean hands at the end of it. new bits e'ry where.
So that's that for now, I will be installing the clutch and then putting it into the car next. Excited
So, lesson. Do more research before completing an engine rebuild so you don't have to take all apart again.
Talky talky.
//oldschool.co.nz/index.php?/topic/52401-pbaines-1971-toyota-corolla-ke25/#comment-1679349
Looking at getting a new compressor as mine just isn't making the cut anymore.
I'm going to be using it for mostly small things but looking to do a few spray paint jobs, especially my KE30 which will be fully done here.
Is this OK? On special at the moment
Today I received my new shims, installed them and also the cams. Pretty self explanatory.
I a have still got to dial in the cams which I will do sometime next weekend whilst I wait for my Dial gauge to arrive.Nearly complete, I have also ordered a brand new alternator and a starter motor also for a good price. still have to order a knock sensor and get the water pump -> back of head lines fabricated with a braided line. Have to do this due to the original piping interferes with the knock sensor, and I am also not running a water based heater so I will not be using those that are included on the original hard lines either.
I have also ordered the SQEngineering COP valley cover plate to suit the 2nz coils that I will be using which I should receive sometime this week.
- 7
3 minutes ago, piazzanoob said:
with everything else looking nice and tidy on the engine i would recommend getting those throttle bodies vapour blasted
hit up this guy
@Mr VapourMr Va@
I agree.
Once I have had everything put in, all the engineering work done to it, the electrical work and the run in etc, then when I take everything back out for the panel and paint I will go through with a fine pick comb to pretty everything up as much as possible.- 1
Today was a good day!
I got my head back from Barry at MRP. Here are some photos he sent me of the head. No need to take my own.
The head had to have some extra work done on it so that the 10mm+ lift cams were able to rotate without hitting anything.
With receiving my head I also received the last few gaskets and bolts that I was after. Especially for the intake side of things so I could get these beauties bollted together.
I installed the front input shaft seal, the output shaft seal, and also the spacer ring between the box and the input shaft that I forgot to install first time round.
Nice new slave cylinder
I am using OEM head studs so I have used the Toyota torque specs, so need to do the +90 +90. I just did it by eye with my last engine, decided to do it properly this time round.
Fastforward an hour of fiddling around I got everything bolted together. I am still waiting on some new shims to arrive from Australia so I will have to wait a little bit before I can install the cams etc.
With that, not long to go before i drop it down the guts into the KE25 and can finally start on another task. I am thinking diff shortening next. Hopefully less expensive than this engine!
Discussion
- 18
Looking forward to seeing more progress!
Well, today the engine came out.
I decided to check, if in fact I did have the original motor in the car.
Yuss. Turns out I do! Fantastic. Very happy to be giving this KE a full makeover and put the original heart back into it.
Just so I remember how all of this went. The rest of the bay is pretty self explanatory
Also showcasing that, I really should have checked if the gearbox had oil in it. Turns out it did, and my efforts of adding an ice cream container 80% through the drainage process didn't really achieve much. #It'sTheThoughtThatCounts.And behold, the bare nude bay. Considering if I should get this entire shell bead blasted or something, just to get rid of all the rusty holes once and for all
I will be going in tomorrow to get some stripper and strip they bay, and also some dry ice so I can get rid of the sound deadening.
- 6
So today I got the spot weld drill bit and attacked the front cowl with it, after a bit of persuading with a coal chisel for the front and the side, and a pry bar to undo any of the spot welds on the inside of the car it all popped off pretty easy!
I think it took about 2 hours to get this off. Some of the spot welds were hard to see externally so I had to pry up the edging with the coal chisel to see between the steel and figure where the spot would be.I will have to get this cleaned up also. Possibly even undo all of the spots for this as well.
Will get this sand blasted I think
As you can see, leaves etc have blocked up the drain holes so water has just sat in there and rusted it all up. I will have to cut this entire patch out, hoping to get a rust cut for this from OCA so will have to see how that goes. In fact I am probably going to be needing many rust cuts, however the problem is that all these KE30's suffer the exact same problems so finding good cuts may prove difficult!!
Next I ripped the entire dash out, simple job. Next I will get some dry ice and get all of the sound deadening out and start on taking the paint off the doors. I will use paint stripper for this, just to see how I get on with that as strip discs aren't cheap when you are using one a day!!
Hello daylight!!
I did some more stripping of this side. I paint strip the rest
Next time:
Sound deadening removal
Engine removal
Door stripping
Interior stripping
Enginebay strippingEuropean babes stripping(my girlfriend said this wasn't allowed )Discussion:
//oldschool.co.nz/index.php?/topic/56136-pbaines-1977-toyota-corolla-ke30/- 3
53 minutes ago, 63Ragtop said:
Thats a shitload of work Man, well done!
it's surprising how much work can be done when no one is around and there aren't any distractions!
Ah, the culprit to all of the roof woes!! I wondered what the knife marks were around the fuel cap, the roof use to have one of those vinyl covers on top of it. I haven't ever seen one of those come out good after 30 years. they all have a mountain of orange metal under them.
I was about to start the front cowl but underneath it was a rusty river so it all has to come off. I drilled these welds out with a drill but have gone and bought a spot drill bit online as I guess it is good to do things properly! I shall resume with the cowl removal on Friday.
As you can see, good I removed these. rusty as, and would hate to think how much is under other panels like this.I finished off some more of the body, overall quite happy with the rear end, a couple of dents but all very easy fixes and over it's very straight so that's a bonus.
Duscussion:
//oldschool.co.nz/index.php?/topic/56136-pbaines-1977-toyota-corolla-ke30/- 11
PBaines 1977 Toyota Corolla KE30
in Projects and Build Ups
More good progress. Shell is now 100% rust free! what a mission...
Anyway. I got the wire brush wheel out on the boot and expected holes for africa, just surface rust for africa so I was pleased
After attacking it i gave it some epoxy
Next came the front panel section at the end of the chassis rail. looks the same as the original repair except this time I will actually seam seal the edges on the chassis rail so no water can get in there... no point repairing it if you aren't going to do it properly!
Tack
Weld:
I thought I would just spot weld the holes but sort of didn't realise how thin the steel was. None the less, the holes are no more
Now the hardest section I have been putting off. It wasn't too hard in the end, just took a bit of time. I also should have used a press for all of this, but. I don't have one!
Step One: Plan
Step Two: Tack
Step Three: Plan some more
Step four: Weld
*imagine pic*
Step Five: Grind off welds
Rinse and repeat
Step One: Plan
Step Two: Plan some more
Step Three: Fiddle around with cutting your new piece up to fit whilst realising you should have done the whole front piece from scratch but then not give up because who wants to then realise they've wasted 3 hours
Step Four: Weld
Step Five: Prettify
Then I attacked the rear boot lip and welded on a nice new one. doesn't have to be clean as possible, the boot rubber will go over it
There was a massive hole here.. don't think I have a photo. Will get the Dremel out and fix the half circle there. otherwise it's sweet
Rear left section that needed doing
This probably looks quite ugly but when I epoxy it it will look good. Very happy with how this section came out with 3 curves I had to compensate for when folding up the cut
Before:
After:
Much better!
Discussion:
