Posts posted by smokin'joe
was mentioning the the run through the middle with my son, but we normally have a tandem trailer on the back. if it works, we could leave trailer somewhere and tag along
often coming through Dunedin, but not in an old school ride.
probably need to organise counter-terrorism when the shit-box marathon comes through in January.
7 hours ago, Xoticskunk420 said:
I’ve tried doing that multiple times but the dizzy can only go in one way
raise dissy, rotate rotor 180degrees, then reinstall.
1 hour ago, tortron said:
Might have been off the system for a while (rather than fresh out of Japan and not regod)
if dead rego before 91-ish ? when the system went digital, it will say plate not issued, never been registered etc
5 hours ago, ajg193 said:
Definitely a bastard to get it all apart
the fucker can stay there, for all the work it does !!
20 hours ago, ajg193 said:
Also, @smokin'joehow is your lathe treating you? Did the currants and raspberry bushes survive?
yes, had a wee play with it, but need to find where i hid my tooling and get set up properly.
we fucked up with rebuild, as i should got a new drive belt installed while it was apart, as it will be a major strip down to replace !! i suspect the motor could either have a wiring issue, or be on it was out, as a bit queer on start-up, wants to reverse rotation.
berries are sprouting new leaves daily and awaiting full transplant, currant-ly in 60l tubs with good compost
10 hours ago, a.craw4d said:
Pics.
need to rebuild it before pics.
we found most of the operating side on weekend. need to find/make barrel and locate the air solenoid
better rebuild the super-Nerf 200.
600mm 1/2 copper barrell12v airhorn solenoid and resivour
12v 4wd-shock compressor
jam D6 reo-bar down inside of Nerf bullet for 200m approx distance. will use lead this time, so i can surf-cast hopefully 250-300m
- 5
On 20/08/2021 at 12:01, gibbon said:
Does that work?
i believe Midwest Motors in Nelson? done it with a stockcar engine. there were videos of it about 5 years ago
9 hours ago, gibbon said:
Siamese block BEAMS v8
so a 1/3UZ with Beams heads ?
haha, so much for not making a start for a month or 2 !!
good stuff -
53 minutes ago, Bearded Baldy said:
Dont 80 series springs fit the back of those for 3-4 inch lift?
have been told they will lift, but lift depends how sagged they were before taking out, shocks shocks fit too but same rule applies
be careful with with lifting @felixx, i put H/D STD height in the 80-series and raised it 95mm rear and 90mm front- 1
my Landcruiser was very close to a fail in similar area. tried to get me on structure, that was over-ruled then had a go over treadblock not inside mudguard. somehow they passed it, as the panel shop said it shouldn't have got one !!
2 hours ago, dabuzz said:
Experience tells me bite the bullet and upgrade the lot to a common size, not worth the hassle persevering sometimes
done this with wifey's notso-Swift. only them and a povo-version Vitz has same tyres as factory fitment. up one size and common as mud
if you are removing the doors to make access easier, ensure you have the door card available for position the side intrusion bars.
whole lot easier to shift the bar during cage build, than to relocate door handles / latches / etc....................... not that i have done it!!!!!
100+ from NPD and the full vacuum lung cleaning method
55 minutes ago, Dell'orto said:
Yep, calipers look to be TE71, and will be T series.
but worth fuck all.... i'll open bidding at a slab of your favourite 375ml tipple
Hollows Timber in Balclutha do 2 calendars.
Tom my son, has a favourite to acquire and admire -
35 minutes ago, KP_wag said:
When your stable of fermentation fridges grows (it likely will), a cheap and effective heater is a single bed electric blanket, $15 from the warehouse and has just enough power to step a ferment to finishing temp
i found waterbed heaters (if one can still buy then) are decent as they are easy to clean. lecky blanky get manky quicky
48 minutes ago, jakesae101 said:
hmm interesting ill try some of the other ones i have.
with the 2 backlash nots loosened, the drive gear on the lead screw is quite loose,,but may some sort 'clutch' engagemeny to shaft ?
3 minutes ago, jakesae101 said:
can you check if the gear from the leadscrew has a small shear pin in it
i don't believe so, appear to be tightly fitted to shaft
13 hours ago, jakesae101 said:
Did you ever manage to check this ?
just have now.
mine isn't in use and was also seized, but it did free up once the backlash? nuts on right hand end were loosened...... maybe some fine swarf got in there, or lube dried up due to lack of use and oiling ?
5 hours ago, jessemk2 said:
Ohh bugger
As good as they are they ain't no landcruiser
for a start, L/Cruiser have brakes, although 6cyl not trubo are allergic to hills
11 hours ago, 87creepin said:
How are the petrol ones for towing other cars?
gearing is all good, but std brakes are average-shit.
braked trailer absolute must and plenty of following distance- 1
Dunedin/Otago meet up and cruise Sunday 12 December 2021
in South Island Region
it could be already loaded, but i like your optimism of a successful day !!
