Posts posted by AllTorque
4 hours ago, Rollamasta69 said:
No I did not. I’m sort of new to this. How would I go about it.
With a timing light
https://www.toyotanation.com/threads/diy-ignition-timing-check-and-adjust-obd-i-93-95.1374553/
Did you check the ignition timing after the new belt was on?
1 hour ago, dmulally said:
Does anybody know what is needed for a wof in regards to smoke?
If there is no smoke once it warms up when you give it a rev, it will pass.
On 13/11/2021 at 21:55, Crispy said:
Everywhere I've read says reverse lights need to work if fitted, but not an issue if they aren't fitted
Correct. Reverse lights are a permitted lamp. So you don’t need them.
Looking sweet.
Don’t get it dirty!
Chin spoiler looks lush.
I am not a fan of the text on the intercooler tho.
On 12/10/2021 at 17:48, tortron said:
$15 Moto1 discount https://loox.io/z/E1_izbANi
I get a discount if you use it. Thx
Thank you. Just got a steering head socket for cheap. Hopefully I ordered the right one.
4 minutes ago, MRWEST said:
So if im reading that right, RX3 Is MA therefore a internal rear view mirror is ok?
Yes, Pre 2000 MA only needs a right wing mirror or an interior mirror,
BUT, if you have tints, you must have wing mirrors on both sides.
(See note 1 in above link)
The virm has just been updated to say cameras can be used in place of mirrors, but it would need to be on all the time the car is on, not just in reverse.
https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vision/rear-view-mirrors
Your 720 Is class NA (Ute) so must have a right side and either an interior OR left side mirror.
(See tables and images in the link above)
New flat deck utes usually get spacers/extensions for the wing mirrors.
- 5
@VintageSpecial I have moved all these posts to this thread.
4 hours ago, Xoticskunk420 said:
just put new plugs in
Did you put the spark plug leads back on the right plugs?
I’m not worried if we have one this month or not, but if we do, wholly bagel might be a good option?
It does not need to work, but it does need to be up so the safety markings can be checked.
That’s just a tease
I had service parts for the Tiger ready and waiting for any potential lockdowns, so I got off the couch today.
Changed oil and filter, replaced spark plugs.
Found it had a K&N. Gave that a clean and re-oil.
Airbox has been modded for max dorts. There is usually only one opening and there should be a snorkel. (Speed Triples have both holes open)
Spark plugs were definitely due
I wish I could go for a test ride.
There is one exception:
“3. A vehicle first registered anywhere between 1 February 1977 and 31 March 1980 may be fitted with a second pair of dipped-beam headlamps”My guess is the VTNZ guys assumed it was originally like that.
Here are the rules https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/lighting/headlamps
8 minutes ago, AntsCars said:
Car is only being built with the intentionally to hand down to my kids
Better do an EV conversion then.
18 minutes ago, AntsCars said:
haven't sized up the 1VD no but figured if people are fitting LS's and UZ's into them
https://www.toymods.org.au/forums/threads/48436-1VD-FTV-V8-Diesel-Information
This guy reckons 1VD is 10-12cm wider and 182kgs heavier that a UZ
Have you sized up the 1VD? They are not small.
For number 2, have you considered a 2GR?
You can have one pair of dipped and two pair of high beam.
Goat's 1977 GL1000 "The black bull"
in Two Wheels
I like the net to catch any parts when they fall off the bike
