Posts posted by Muncie
Well that's black and white been a while since I read the LVVTA bible......
Current plan is obtain a bumper beam not mess with it and sneak a less tall intercooler under it same specs just not as tall can carry on as is for now get it running and worry about this later. As pipework locations will be same.
Got lots to fabricate intercooler pipework a battery to move and wiring for my reversed inlet manifold to do.
@cletus I take it putting intercooler pipes through panelwork in engine bay is a no can do now? Eg coming through where airbox was and battery. I can try squeeze it between radiator but would rather not.
28 minutes ago, cletus said:
Cert= can't cut that bumper beam unfortunately
Well fuck.... lucky I kept the piece I cut out. I'll work on moving it back further.
Could I get a replacement fabricated Or its just new car stuff that can't be messed with?
I won't lose sleep tonight over cutting a removable part as a smaller intercooler is always an option.
Thanks for heads up.
Took this to Frankton Thunder this year and to KFC once..... I reckon it's safe to pull off road now and make a start on the final push.
Hoo roo bumper! I need an intercooler in here.
Bumper support is obviously in way and power steering cooler just behind it.
A bit of force moved the power steering cooler and its bracket easily enough.
Thought I had crossover pipe all sorted so did wee trial fit today found it ends up straight into sway bar mount.
Fuck it re do it all. Turned out nice had a good few hours asphyxiating my self with argon loved every minute.
Engine is now sitting at the perfect angle I can see it in garage from dinner table.
Thanks I'll see where it sits in car as closer to firewall = shorter wiring back to controller and ecu.
Wonder if turbulence from wastegate will be an issue.
Code scanning is a little convoluted for commodores though Envious Customs in Oz has reverse engineered it all now and you just buy a lead and software and you can do most things, like clear airbag lights turn off your seatbelt chime and replace your start up message with HSV or a dick and balls.
Ford made me laugh as one software I tried was called Forscan......
I'm on my 3rd of the bloated whale shape vt-vz commodores VY would be my pick of them nice dash kind of modern not so much tech you can't fix it yourself engines are simple but go well, for a service you can do it with an 18mm spanner a flat blade screw driver and a good size hammer.
Parts are cheap enough and available off Rockautoparts.com because they got the Monaro (Pontiac GTO) and Statesman in the us (as police cars) and are quite popular still.
I had both VK VL and VN which I loved as they are quite light but water soluble and rust out in hard to reach places.
I'd love an FG turbo Falcon but rust scares me ive looked at a few and found blisters in places I'd hate to repair (but Barra power Phwoar!!!)
Are the thrust washers (in engine) shagged? Check endfloat of crank I battled clutch problems for ages because I didn't want pull a running engine out.
They can fall into sump if your real unlucky engine will run fine for a while but you will add a couple off mm to your clutch stroke.
See below not much too them
These might may just stay in Taiwan for now. So cheap yet not cheap enough to risk been garbage.
The ones on trademe are these, how can you sell stuff that's bogus in nz?
Been looking around the marketplace for new springs and shocks for my VY COMMODORE guessing the algorithm noticed. I'm not looking to slam my car but some flexibility would be nice if it were adjustable led me to finding below Maxpeedingrods coilover setup incredulously cheap!
It will be road legal im not about TikTok views so needs to get thumbs up from a certifier down the track.
But seriously is this a scam or manufactured from Taiwan grade cheese alloy. All the parts are infact commodore shaped and instructions do list what they don't fit indicating they have some feedback.
Back off again till I find some Ford Ranger flares or something. They'll work im just not going to commit automotive butchery today till I think about it a bit more.
Yeah these are made by Ronal, ive always found a factory made set of rims so much more hardy with potholes and shit roads. And spokes that go to the edge although not as cool as a lip are stronger again.
Been a while I very nearly got knocked on a WOF before drag day as my rear tyres are down a bit on tread some life left but not much.
I bought some 275 tyres to see if they might fit as I want meats out the back. Fluked these BMW X5 m Spec rims in 19x9 front and 19x10 rears off market place today for basically scrap value. They should look mint! Can also chuck a 255 up front as well.
Turbo stuff not on hold as such just doing my bit with small stuff like catch cans and power steering reservoir and radiator over flow relocations.
Meanwhile its nice driving it.
On 30/01/2024 at 08:48, yoeddynz said:
Picking myself up now.
Just buy a Triumph 2500 S dash gauges look nice enough will work with your 6 cylinder (probably) and add a oil pressure gauge. Good budget option
I'll keep it in mind for an option but I've just put a wastegate right where the inlet is there and tge plumbing where the coils are.
Might work better for someone converting a hilux or something. Cool to see how yanks set them up though.
Daves new school holden shambles
in Other Projects
It will fit behind the bar if i remove the air-conditioning which I've spent quite a bit of extra work already trying not to do. I did try leaning it but would need to be on such an angle it wouldn't work and block airflow for radiator.
Catch 22 there's definitely a way so many others have done it already.
