Posts posted by shrike
Id be doing a front/mid/dry sump and or a modified/custom cross-member before cutting/massaging the engine bay if it was me
Interesting that the 2GR and 4GR bolt patterns are different, but in saying that I know its been mentioned the RWD vs AWD/FWD blocks had different gearbox pattern
21 minutes ago, Roman said:
4.3 ratio F series live axle
Open or LSD? F series can have Altessa LSD centres installed yeah?
Submitted for @Adoom’s approval.
Those cam gears need some speed holes, lots of lightening opportunities for max RPM right??
Hey Remind us what diff/ratio you have in this?
Just a note re DBW ITB the 2022 Honda CBR1000RR has 52mm DBW ITBS
Not sure if that's Inner Diameter however, I suspect the 48mm BMW S1000RR ones wouldn't be a limitation even with boost however
48 minutes ago, xsspeed said:
Kinda weird it has a big boi box
Same box as in the Toyota Tacoma, think its just a parts bin special
12 minutes ago, Roman said:
That box looks way different, bit bigger as well I think. Likely R series like R154 sorta thing.
J160 might be a little on the fragile side, but hooning rpm through it rather than a big torque bomb should help in that regard.
Although interesting to see that the start motor is indeed on the engine side on that box.Its meant to be based off a truck motor so possibly similar to the R150 etc range but a newer design
The IS250's AY6/RA62 transmission
https://www.ebay.com.au/itm/264496988179
https://en.wikipedia.org/wiki/Aisin_AY_transmission
Isn't the J160 also an Aisin box? I'd say it has more aftermarket support as well currently if you can make it work with the engine
Re ITB if you could sync both tps couldn't you join the signal and divide it by 2 and then have the output go to both DBW controllers?
Possibly oversimplifying this
Thoughts on clutch options? guessing for your power level needs you won't need anything too aggressive
Any plans to keep the DI and then also run port injection? or just going port injection as its easier.
Im tipping with a decent intake and exhaust your looking 200kw, maybe a little more with some cams/headwork/aggressive timing
3d printed gearbox adapter converted to metal
From memory Lexus also had a manual varient with a *GR engine.
There was a thread on toyomods comparing The 2GR and the 1GR I think
https://www.toymods.org.au/forums/threads/65328-2GRFE-Conversion-any-inputs
Nice, know some ex Toyota Australia people that think the 2GR is one of the best motors Toyota has made and the 4GR is just less capacity.
Apparently they make ok power with a intake and exhaust change as the factory stuff is restricted and they run factory rich
I know you'll do your magic though, hoping for DBW ITBs again
Some Hiluxs had the v6 as well so may be able to use a RWD box from that family.
15 minutes ago, d.p.n.s said:
cheers man.
the headers have been coated..we actually put a model of a mk3 in a wind tunnel .. just on the internet one night while having beers.. and there's a low pressure area right at the back of the bonnet and it will actually restric air coming out. (I know I've got some real needs as mates lol). but at the half way make on the bonnet like where they are and the factory cosworth as well as evos and heaps of other cars ... the air going over the bonnet helps pull the heat out.. (that's my understanding of it.....I was drinking ...they were explaining)....... even though lifting the rear of the bonnet was my 1st plan.... probably not now.
Makes perfect sense, yeah no point lifting the back if its not going to help
Hopefully it helps drop down the engine bay temps be keen to see the before and after
Going to space up the rear of the bonnet with some washers to allow some heat out the back as well?
Can't remember bit are you going to coat/wrap your exhaust setup?
Bonnet vents look good in my mind
55 minutes ago, yetchh said:
Apparently 4agze injectors fit also.. If I could go to a modern injector that would be excellent.
From memory, 4agze injectors are 365cc
These are top feed correct? Any idea on length? Pretty sure Toyota 1NZ-FE injectors are the same/similar size and have better hole pattern/atomisation.
Common to swap them into the 1gfe Lexus IS200 as they run better
@Roman can you confirm?
Edit 1nzfe injectors are high impedance
Any idea what the drum vs disc rear end weight difference is? If not would be keen to read about it when you do it :p
I'd also be keen to understand if it gives you slightly better braking performance, remind me are you getting any brake fade currently? In saying that swapping out pads each track day is surely easier then swapping drum shoes?
Hopefully sideskirts make a difference, I think they look good though.
Curious on how you utilise the filter options and see what you come up with.
What year 4g93? Early model (GSR same year as evo 1-3) will be narrow block and will use the same narrow gearbox as the 4g63s use
Fuel mentioned that l200 1980 onwards have the narrow block gearboxes or the RWD Sigmas
7 hours ago, mlracing.co.nz said:
Ohh nice, I might just end up buying one as I have a few other cars that could use the treatment. Which part of Melbourne are you in ?
No stress, I'm out in werribee
Have a digital timing light plus a cheap strope one (didnt work on wasted spark) and also in Melbourne your welcome to borrow s3nd me a pm and can sort it in the new year
Remind me is this running an electric waterpump?
If so is it running a constant or varible flow rate based on criteria? What are the thermostat dimensions? Be interesting to see how it compwres to say a 4age one size wise.
What temp does the thermostat open at?
Edit: google says Japanese Prius Tech Manual says the thermostat specification is starting to open at 82C (180F) and fully open at 95C (203F)
Can always drill a couple of holes into the thermostat if need be right?
Exhaust looking good, I know you mentioned your not keen on exhaust wrap, could always look at ceramic coating? or alternatively maybe some heat shields to help keep heat away from things?
I normally run my radiator temp sensors in the top rad hose as that's generally the hottest point and run the fans off that. Are you going to also set the ecu up so that the fans turn off at a certain speed? From memory anything over 60km and the fan is useless, can't remember but do you have shrouding on the rad with the fans? Any flappers?
Be interesting to chuck and air intake temp sensor in front if the rad as well
Keen to read about results
Yip sold being picked up tomorrow, guy that's buying it will be getting it finished off professionally. It's his 4th one he's brought (sold his last one when his son was born) slightly conflicted about selling it as I doubt I'll ever be able to get another one
Got a few spares I'll have to sell separately but got a price im happy with, and gives me some space back ete
Stay tuned on what I end up getting next. (Probably be end of next year)
Hoping a few things will come up as interest rates rise and people have less cash etc but will keep an eye out for deals/what pops up at the car auctions
Roman's 4GR V6 Carina discussion thread
in Project Discussion
So back to the 2AR as an alternate again, depending on height to fit.
China/Russia/Thailand got a 6AR which is 86x86mm (2L) how would a crank from a 6AR (sourced from thailand) go in the 2AR as a destroke from a rod to stroke perspective?
Custom rods maybe needed or to raid the parts bin ror something suitable
Looked at the new corolla engines (m20a) ?
