  • Replies 58
Rear axle is a severely narrowed Ford 9"
It has 35 spline shafts, Strange centre section with Strange spool and 4.11 gears.
Suspension will be adjustable coil-overs and adjustable 3-link.
Rear brakes are Falcon rotors, calipers and internal handbrake.
The engine is quite a tight fit in the bay, and the available height is a lot less than my old car that the engine came out of.
The 'old' intake manifold was quite tall and would have required a huge bulge to cover it, the two blow-through Holley 4-barrel carbs and the pressure hat.
The manifold stood nearly 200mm tall:
  • Like 8
The top of the rollcage has been painted. This was done as, with the roof fitted there is no way I could get paint all around it.
And with that done, the roof can go back on:
One of the dimple-died screen gussets in place, the other will follow shortly....
  • Like 9
The transmission is a Getrag 6-speed from a 2012 Mustang, and it was slightly too big for the transmission tunnel:
So I've put in a steel framework, this will be covered in removable aluminium panels to enable easy access:
  • Like 8
For clutch and brake I was lucky enough to score this Wilwood pedal assembly cheap:
This attached to the dashboard bar of the rollcage:
Held in by 4 x 1/4" UNC bolts at the top and 2 x M8 bolts at either side.
Time for some more paint to be splashed about!
Front hubs are now painted and fitted with their larger-than-standard taper-roller bearings:
and after adding a couple more tabs just in case I ever fit wheely bars, the back axle casing:
With the Ford 9" axle ready for final assembly, my attention turned to the links for it.
Lower links are very straightforward, left and right handed rosejoints and a couple of sturdy tubes:
Upper link (yes, just the one) is a bit more complex:
The two forward rosejoints are the same size as the lower links, the single axle end one is far larger.
  • Like 8
