  • 3 months later...
Side quest time
I got bored and had a little play with this, threw a coil at it and poured some mix gas down the hole. Barked off, revved and even fucking idled.
Headset bushes are wasted, need to spin up some brass and replace. Im too keen to go for a cheeky hone so will see how much i can do so i can annoy the neighbours one fine sunday arvo
Chur
Changed the tank as it was crusty inside and thoughts this old villiers one looked the part, ment i had to shorten the seat a tad.
Tried to start it again but no real luck apart from some pops n farts. Pulled the carb and it was pretty gummed up, now it flows but also profusely pisses on the ground so the float needs to be adjusted
Looking the part though
